Codes P0573 & P0501 help
Old 20 Oct 2017, 09:38 am
Default Codes P0573 & P0501 help
05 PT GT 5Spd
Getting the P0573 brake switch A circuit high
Brake lights work correctly. Brand new battery,
I've disconnected the battery to let the ecm reset multiple times, cleared the codes with my reader a few times.
Still comes back, so obviously I have to figure this out.
Not much help on Google.
Sometimes, the CEL doesn't come on for a few minutes
And sometimes, the TRAC/ABS lights come on (but not very often)
I'm also always getting an accompanying P0501 vehicle speed sensor code, but that's because my Speedo sensor is on its way out. Only works when you are on the gas. Otherwise it falls to 0 or twitches. Already did the gauges test. Gauges are good.
What am I looking for?
Please get technical
Old 20 Oct 2017, 10:15 am
Default Re: Codes P0573 & P0501 help
Originally Posted by bricks4584 View Post
05 PT GT 5Spd
I would suggest that your P0573 code could be triggered due to the vehicle speed code being triggered. The PCM looks at the speed and triggers the P0573 if it is out of range. Recommend you fix the cause of P0501 first.
Help Please P0501, FL0007, EE13, BLO1 BlackPhantomZ28 Tech & Performance Forum 5 14 Nov 2015 10:16 pm
manual trans. code p0501 - speedometer not working shelbyzman Tech & Performance Forum 3 02 Jan 2014 04:26 pm
Dash codes--not the usual OBD codes--help! chitowncruiser General PT Cruiser Discussions 5 01 Mar 2013 11:56 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
