Higher idle
  • 1 Post By ptcruisersteve
Old 21 Oct 2017, 10:24 am
RVC RVC is offline
Default Higher idle
I recently completed a head and timing belt job. All seems well except that from the beginning it kept throwing an 0401 code which I will be working on soon. Recently idle has gone up from around 900 rpm to around 1500 (engine in neutral or park) more or less.
Are the two issues related?
Thanks.
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
Old 21 Oct 2017, 11:19 am
Default Re: Higher idle
P0401 - EGR flow insufficient
The 2001 and 2002 had a special EGR pipe attached to the upper manifold in the back. It's held on by 8mm & 10mm nuts and has to be seated just right.
If someone removed it making repairs on your Pt Cruiser they might not have gotten the pipe correctly seated into the back of the manifold. That would cause a leak in the EGR system and possibly set off the code.
If no leaks I would check the related pipes and see if the are clogged up.
CREWZIN likes this.
Tune-A-Can Exhaust - Higher MPG?! wingman55 Tech & Performance Forum 6 21 Jul 2017 03:28 pm
higher price = higher quality? edb General PT Cruiser Discussions 13 26 Oct 2011 04:05 pm
Having To RUN Higher Octane???? tcr1016 General PT Cruiser Discussions 23 30 Dec 2010 01:02 am
Chrysler Tilts Toward Higher MPG skylight PT Cruiser News and Rumors 2 24 Oct 2007 12:58 pm
