Electrical System Fried. How do I know what to fix?
Like Tree4Likes
  • 1 Post By _PTGT03
  • 3 Post By ptcruisersteve
Old 22 Oct 2017, 03:06 pm
Unhappy Electrical System Fried. How do I know what to fix?
2002 Limited Edition 5-speed manual. 106k miles.
I made the mistake of getting distracted while jumping my PT, switched up the cables, and fried it... The cables were connected for less than 30 seconds and I turned off the powering car first before disconnecting. PT won't start and the digital odometer won't come on. No electricity works in the vehicle. Where do I start if I want to self-repair? Fuses? Circuit breaker? Wiring?
I had not driven it in a while and was going to polish it up before selling it but ended up frying it... Most I can find someone to offer to pick it up is $125 since it won't turn on but it's in decent condition and would like to get something more out of it. Any advice is welcome.
Old 22 Oct 2017, 03:48 pm
Default Re: Electrical System Fried. How do I know what to fix?
First and easiest things to check are all the fuses, both under the hood and in the interior.
Old 22 Oct 2017, 03:59 pm
Definitely! I felt so defeated after my dumb mistake I haven't checked the car out... I will check the fuses when I get home in an hour or so.
After I burned up the first (CHEAP) pair of jumpers, I went out and bought another pair and attempted to jump the car again (correctly this time) with absolutely no response from the car.
Old 22 Oct 2017, 05:02 pm
I check both sets of fuses and everything checked out fine. I'm sure that's not good news for me. What would be the next step to identifying what electrical system part is broken?
Old 22 Oct 2017, 05:19 pm
OK, you have some reading and listening to do..... Hope these help.
Cranked 2008 PT cruiser with battery hooked backwards
need help with fuses!!
Stupid mistake, now won't turn over
Old 22 Oct 2017, 11:01 pm
_PTGT03's Avatar
it's going to be the biggest, main fuse on the car. don't feel like an idiot, it happens to the best of us sometimes !
podo2000 likes this.
Old 23 Oct 2017, 10:52 am
Are you checking to see if you have any voltage going to the fuses?
Old 23 Oct 2017, 11:05 am
Sinbad's Avatar
Are their any "fusible links" within the wiring on a PT? Often you find these look like slight bulges in the wires going away from the battery to the electrical equipment.
Don't feel stupid - some people voted for Brexit.
(Troll )
Old 23 Oct 2017, 01:21 pm
Also suggest checking the battery. 30 seconds is a long time and might have damaged cells in the battery. If you have enough shorted cells you might not be able to jump start it.
ptprice, JoeX and Sinbad like this.
Tags
dead, electrical, repair
Electrical System Cuts Out Ikster Tech & Performance Forum 6 24 Jan 2014 05:55 pm
07 vert electrical system mel_d PT Cruiser Convertible Forum 0 21 Oct 2011 03:58 pm
IDK if my system fried my harness phil2park2 Sound and Security Forum 11 13 Aug 2010 06:33 pm
Overhead console with screen or dvd player, also posted in electrical system thatsmrjptou Interior Accessories Forum 0 27 Sep 2009 06:26 pm
electrical system question Thrusst Turbo Performance 1 09 Aug 2007 06:52 am
