Replaced ECM, now trans downshifts different
Like Tree2Likes
  #11 (permalink)
Old 24 Oct 2017, 02:49 am
Default Re: Replaced ECM, now trans downshifts different
Will do.
2003 GT Turbo AT
  #12 (permalink)
Old 24 Oct 2017, 08:19 am
AAMCO. All Automatics Must Come Out. That's all I'm saying.
Ignorance can be educated, crazy can be medicated but there's no fixing stupid!
  #13 (permalink)
Old 02 Dec 2017, 01:10 pm
OK, I know it's been awhile, but I finally solved the issue. Took the car to the dealer, and they did the quick learn procedure, and the problem went away, at least it didn't happen again on the 8 mile ride home. They charged $105, less than their hourly rate of $130. They wanted $267 to change the trans oil and filter. I'll be doing that myself, thank you!
PS: AAMCO and the local repair shop I've used before wouldn't touch it.
2003 GT Turbo AT
  #14 (permalink)
Old 02 Dec 2017, 02:10 pm
rckstein's Avatar
Thanks for coming back to report the fix.
The ODB Quick Learn procedure is discussed in the Gen1 and Gen2 Service Manuals, and I have mentioned it several times. But each time that it's brought up, the naysayers try to discount the procedure.
It fixed my transmission shifting issues after the solenoid pack replacement, any my dealership charged about the same as yours did. So, IMO, it was $ well spent.
myckee likes this.
'06 Touring Edition NA Automatic
151k Miles / Electric Blue Pearl
USMC '82 - '93
  #15 (permalink)
Old 02 Dec 2017, 02:38 pm
Did the dealer check for transmission codes and let you know if there were any?
I took my Pt Cruiser in under warranty for a different issue and the service person said something about a transmission code being triggered in my Pt Cruiser but would not tell me what the code was. I had to go back several times before they gave up and gave me the transmission code. My impression is that sometimes they will just make adjustments and not inform the customer that a code has been triggered.
  #16 (permalink)
Old 02 Dec 2017, 02:55 pm
rckstein's Avatar
At the dealerships that I use, during the check in process the service advisor plugs a pod into the ODB. This not only reports the vehicle ID to their tablet, which then does a quick service history scan so they can upsell any of their services, but it also does a code scan, for any issues, as well as any pending software updates waiting to be incorporated to the vehicle. Whenever it has shown a code, the service advisor will gladly show it to me.
This pic is of the codes when the TIPM replacement was producing codes, because it needed dealership programming after it was installed:
USMC '82 - '93
  #17 (permalink)
Old 02 Dec 2017, 03:06 pm
It's possible that the process is different whether you have a vehicle under warranty or not. My Pt Cruiser was under warranty so they probably were trying to keep costs down.
Was yours under warranty when they gave you the report?
  #18 (permalink)
Old 02 Dec 2017, 06:22 pm
glad you got it sorted
  #19 (permalink)
Old 02 Dec 2017, 07:16 pm
rckstein's Avatar
I had my PT at the dealership several years ago and it was no longer under the factory warranty, when they plugged in their ODB module and found a software update that needed to be incorporated to my vehicle. It was a no charge driveability software update. That was pretty good customer service in my book, when they told me about something that my vehicle needed and it was at no charge.
The one in the pic above my vehicle was no longer under warranty, but I knew there would be a charge because only the dealerships have the STARSCAN equipment capable of programming the TIPM.
USMC '82 - '93
  #20 (permalink)
Old 02 Dec 2017, 08:41 pm
Thanks, guys.
Steve, the dealer didn't mention any codes. The shop that refused the job, I did get them to give it a quick scan and there were none.
2003 GT Turbo AT
Replaced almost everything. Really need help Nealpeters General PT Cruiser Discussions 8 24 Apr 2015 08:34 pm
replaced rad....now low speed fan won't come on joereott21 Tech & Performance Forum 5 29 Jun 2014 04:34 pm
Replaceing PT cruiser Trans- Prepping trans questions Wiredright Tech & Performance Forum 6 13 Feb 2013 10:59 am
AT- Downshifts hard clok1966 Tech & Performance Forum 9 17 May 2011 12:04 am
Unexpected downshifts downhill on GT w/Autostick KevinM Turbo Performance 4 30 Sep 2003 06:04 pm
