Splicing manual speed sensor on an auto harness
Like Tree6Likes
Old 26 Oct 2017, 07:12 pm
Default Splicing manual speed sensor on an auto harness
Is it possible or is it out of the question? I have the pigtail for the speed sensor and Iím trying to get my cars speedometer working
Old 26 Oct 2017, 11:29 pm
_PTGT03's Avatar
Default Re: Splicing manual speed sensor on an auto harness
you're missing too much important information for someone to help you. what isyour issue experienced and what have you done
Old 27 Oct 2017, 10:59 am
rob302's Avatar
need to know what year the car is you stole the turbo junk from.
if all = 2002 it would look like below.
Old 27 Oct 2017, 11:03 am
rob302's Avatar
what you are attempting to do involves wiring that used to go from the pcm, to the tcm, and then to the trans.
would be better/easier to just look up where the wires come out of the new PCM and run 3 new wires. idk what year or type of computer you're using. i'd ASSume it's for a manual GT?
Old 27 Oct 2017, 12:37 pm
The ecu came out of an auto GT and the harness came out of an 05
Old 27 Oct 2017, 01:50 pm
rob302's Avatar
^2005 GT
this may help?
Handy_Cruiser likes this.
Old 27 Oct 2017, 01:52 pm
rob302's Avatar
match the 1, 2, 3, to the diagram above and it should work.
check with a multimeter to verify which wire is the power and which is the ground. failing to do so may cost you a PCM(which i do not want the credit for)
Old 27 Oct 2017, 02:24 pm
rob302's Avatar
wire 13 on PCM connector 1 = speed sensor output connector pin 3
wire 29 on PCM connector 2 = speed sensor output connector pin 2
wire 27 on PCM connector 2 = speed sensor output connector pin 1
(but double check me)
Old 28 Nov 2017, 11:59 am
I have also swapped an automatic 4 speed for a manual 5 (NV150) in my 04 PT turbo lite.(Non GT) I have been struggling to get the speedometer working. I came up with the same plan you have listed here after weeks of trial and error. The ECM is the original 04 turbo automatic, (Non GT). I have my wires hooked up as you describe here but still no reading. I have replaced my speed sensor, the nylon gear that attaches to it, and my cluster. Both clusters' tested ok for the speedometer. My last hope is the connector on the harness I made from the sensor pigtail pin 3 is faulty.
No disrespect to you at all but, how sure are you that pin 13 on connector 1 (Speed signal MTX) will take a reading if the ECM was programed for an automatic? I'm beginning to think its a dead pin.
Thanks for your help. I wish I had seen your post before figuring it all out on my own. dan@ju-online.com
Old 28 Nov 2017, 12:24 pm
rob302's Avatar
i've never been through it.. i don't think i'd try this swap myself.
if pin 13 is unused, perhaps the auto PCM uses this for reading speed?
if all else fails you might contact autometer tech support and see if they have something that may work. i have in the past used their programmable electronic speedometer. basically you drive 2 miles and stop and it calibrates itself. only downside is $$ and you'll lose cruise control.
https://www.autometer.com/media/manual/2650-1512.pdf
Need '01 5-speed wiring harness TurboDucky Classifieds: Want To Buy 2 08 Feb 2016 09:36 am
Do I need to change sensor/s on my 5-speed..got auto throttle body shelbyzman Tech & Performance Forum 3 26 Jun 2013 04:52 pm
Looking for '03 GT PCM and Wiring Harness from a 5-speed car TurboDucky Classifieds: Want To Buy 5 08 Apr 2012 09:26 pm
wiring harness 05 manual non turbo BeagleDad Tech & Performance Forum 3 26 Aug 2011 04:21 pm
05 non turbo manual trans wiring harness BeagleDad Classifieds: Want To Buy 0 26 Aug 2011 03:16 pm
