Cooling fan
Like Tree3Likes
Old 28 Oct 2017, 11:50 am
oldthom's Avatar
Default Cooling fan
My old cooling fan had low speed only so I bought a new fan off eBay and changed it out. The new fan works with high and low speeds but drags the engine down to a rough idle no matter what speed it is running. MY OLD FAN DID NOT DO THIS. I disconnected the battery and cleaned out the IAC and throttle body, checked everything in the way of a possible vacuum leak and it still does this. With the old fan the idle stayed smooth just no high speed. I am ready to try another fan unit. Can anyone recommend a quality cooling fan? Is Dorman the brand I want? Or is there a better one on the market? I replaced the IAC motor with a new OEM from Chrysler and it didn't help. What fan have you used??
2004 LE "Dolly" 61K miles
Old 28 Oct 2017, 12:45 pm
Default Re: Cooling fan
Does the engine run rough with and without the A/C on with the engine cold?
Old 28 Oct 2017, 02:18 pm
oldthom's Avatar
Just with the AC on. Otherwise it runs smooth
Old 28 Oct 2017, 02:43 pm
Are you getting a diagnostic code P0481?
Have you had any problems with the A/C before replacing the radiator fan?
Old 28 Oct 2017, 02:47 pm
oldthom's Avatar
Steve; I ran it without the fan and the AC on. It ran fine. I'm thinking I got a fan that has a brush problem or short that causes it to draw to much power. I choose to replace the fan with a better brand. I now realize I should not have asked folks to recommend a brand name, it's kind of putting them on the spot. I'll choose one and go with it. Thanks.
Old 28 Oct 2017, 02:49 pm
oldthom's Avatar
Just seen your last reply. No, no problems at all. No codes as of this morning, I checked with a scanner.
Old 28 Oct 2017, 09:13 pm
Question Re: Cooling fan
Would like to find some one that can tell me what the TIPM module does for the grounding of the high speed fan wire and activate the fan n relay.
I have trouble shot all the way back to the dark blue / w pink tracer wire to the termination enters the TIPM module. I can ground the wire at this point and the fan works just as it should.
There is a code P0481. I am not sure what to look at or for next. Any and all advice is greatly appreciated.
Old 28 Oct 2017, 09:20 pm
Welcome to the forum.
Please start a new thread on your issue. In the meantime go to the welcome thread and introduce yourself.
Old 28 Oct 2017, 09:26 pm
I usually buy Dorman radiator fan at Rockauto,com.
oldthom likes this.
Old 29 Oct 2017, 01:43 am
IF your fan was pulling more than the designed AMPs the wiring to the fan would most likely
get warm or hot and start showing signs of heat like burning .
The ground is constant to the fan, check you left fender grounds , if they are oxidized redo
the grounds, I cut the grounds back about an inch and soldered the grounds to new eyelets.
Check battery cables for corrosion.
Sorry not good at typing at 3 in the morning
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Cooling fan! jcamp General Turbo Discussions 13 18 Jul 2016 08:58 am
cooling fan wlwhockey101 General PT Cruiser Discussions 2 02 Mar 2016 11:00 am
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in rdvarona Southeast PT Forum 18 31 May 2013 09:14 pm
AC cooling fan-what now Cajunsim Tech & Performance Forum 3 24 May 2013 11:34 am
Cooling Fan StealthyK Tech & Performance Forum 2 12 Apr 2011 02:16 am
