01 pt cranks, no start.
Old 28 Oct 2017, 01:51 pm
Default 01 pt cranks, no start.
pt cranks wont run. replaced coil,wires, plugs and CPS sensor. No spark unless i unplug CPS sensor. Then i get backfireing. no start.
Old 28 Oct 2017, 01:58 pm
Default Re: 01 pt cranks, no start.
Is your engine light on? If so what diagnostic trouble codes are you getting?
Old 28 Oct 2017, 02:27 pm
no codes.
Old 28 Oct 2017, 02:30 pm
no lites. no codes.
Old 28 Oct 2017, 02:37 pm
no lites. no codes.
How are you checking it for codes? OBDII Scan Tool or key dance?
Old 28 Oct 2017, 02:41 pm
Obd11 scanner
Old 28 Oct 2017, 02:50 pm
I would suggest you check the wiring, connector going to the crankshaft sensor and the crankshaft sensor itself.
On the 2001 &2002 Pt Cruiser there is a common problem where the wire harness drops down from the bottom of the engine to the half shaft rubbing on it burning through the harness and shorting out wires including the crankshaft wires. Check the wire harness.
Old 28 Oct 2017, 03:08 pm
How would I check crank sensor? Voltmeter, Ohmmeter?
Old 28 Oct 2017, 03:31 pm
This link below might help you check the crankshaft sensor. It is specific for a 2001 Pt Cruiser.
Part 1 -How to Test the Crank Sensor (Chrysler 2.0L, 2.4L)
06 PT cranks no start drumrooster Tech & Performance Forum 36 25 Feb 2017 09:22 am
Cranks but no start? C300392 Tech & Performance Forum 4 15 Apr 2016 07:58 am
Cranks, won't start (bad PCM ???) dxv77 General PT Cruiser Discussions 14 26 Jul 2015 05:19 pm
05 PT cranks but won't start. Noah1 Tech & Performance Forum 5 22 Jan 2015 03:38 am
Cranks but want start stickkman99 General PT Cruiser Discussions 8 04 Aug 2013 12:00 am
