Codes, 0452, 0499, 0462 and a trans Battery Voltage Low
Old 28 Oct 2017, 04:54 pm
Default Codes, 0452, 0499, 0462 and a trans Battery Voltage Low
Just purchase a 05 PT Convertible with a turbo. Second day throws these codes, P0452, Evaporator Control System low, P0499 Fuel Tank Pressure System Low Valve Solenoid, P0462 Fuel Level A CKT Low Input, The last was a Trans Battery Voltage Low. Any thoughts?
Old 29 Oct 2017, 08:19 am
Default Re: Codes, 0452, 0499, 0462 and a trans Battery Voltage Low
Go get the battery load tested and if bad, replace it. Clean the O-ring on the gas cap and clean the gas tank filler neck where the gas cap screws on. Lube the O-ring with some WD-40. Clear the codes and see if they come back.
P 0462 fuel sender voltage royleroyleroy General PT Cruiser Discussions 4 25 Jan 2016 09:41 pm
Voltage Regulator/Battery chris15 Tech & Performance Forum 5 25 Nov 2011 03:19 pm
Charging system battery voltage DJmart Tech & Performance Forum 19 14 Sep 2011 11:26 pm
No start/stalling, plus 2 trans codes PMO623 Tech & Performance Forum 7 11 Mar 2011 01:01 pm
0499 code Axshun21 Tech & Performance Forum 18 30 Aug 2010 02:43 pm
