Engine cuts out !!
Like Tree6Likes
  #21 (permalink)
Old 04 Nov 2017, 03:12 pm
Default Re: Engine cuts out !!
Originally Posted by Sinbad View Post
It's good enough for now if he's got a cutting out scenario and it's starting the car Steve.
Yes, he more than likely needs a new battery, although we don't know, and 11.7v in a gaff that likes selling batteries is... well... maybe marginal when we don't know how much work it had done before he took it there - but the CRD batteries are an arm and a leg, and he should give himself a chance to shop around rather than go out and buy the first one he can.
You can get a decent battery for the petrol over in Europe for 50 / 50 - for the CRD you can get striped and pay 250 / ... or find them as low as 120...
The cutting out scenario can be from the battery voltage going too low. Without physically being there it's not a good idea to give advice on allowing a diagnosis to be performed when you might have a bad battery.
Best thing would be to take the battery to several different places to confirm the battery is bad. If you have a battery charger you should charge the battery first before getting it tested.
  #22 (permalink)
Old 04 Nov 2017, 03:41 pm
Sinbad's Avatar
Battery voltage on test was 11.7v - and he is now going to charge it overnight, which tells us he believes it might have been a bit on the flat side.
CCA is low compared to a new CRD battery, but whatever...
Best we close the forum right now then, before anybody gets hurt...
Tags
dashboard lights, engine light flashing
Engine Cuts out alanrw Tech & Performance Forum 65 09 Jul 2016 01:58 pm
Engine cranks, but cuts off. LemonOnWheels General PT Cruiser Discussions 4 15 Mar 2014 11:47 am
PT engine cuts out when starting with AC on mmhendrie Tech & Performance Forum 12 22 Jul 2013 10:04 pm
engine cuts off while driving leesa47 Tech & Performance Forum 2 19 Apr 2012 11:14 am
Engine cuts in and out at 2200 RPM tomrinsb Tech & Performance Forum 21 13 Oct 2008 04:50 pm
