Key in ignition
Like Tree3Likes
  • 3 Post By LionPT
Old 04 Nov 2017, 03:54 pm
Default Key in ignition
I have a 2008 PT Cruiser with 230000 miles on it. I had an issue where the vehicle did not start had the electronics replaced on it. That was about a year ago. Now its saying Key in ignition even when the key is not in the ignition. And the FOB does not work. If I reset the computer I can lock and unlock with my fob several times till it hits that error. I cannot find a way to remove the key cylinder
there is a small yellow tab under the ignition that I can push out and remove what ever its hooked to but have not in fear of breaking something. If you need pictures Ill send them .. Do I need to replace my entire Key system...
thanks in advance OH BTW it drains the car battery after 2 days of not driving it and I have also changed the fob battery 2 weeks ago thinking that was .t
Old 04 Nov 2017, 04:10 pm
LionPT's Avatar
Default Re: Key in ignition
This should help...
Old 04 Nov 2017, 04:15 pm
This is what I LOVE about the PT Cruiser Forms
Ill give that a shot tomorrow I appreciate the info..
Ill let you know what happens..
Old 10 Nov 2017, 07:23 pm
I have taken the multi function switches off and there is a black piece that is right behind the steering wheel. It looks like it can only be removed with the steering wheel off. I can reach the hole but Nothing works not even the 1/16 bit.
any ideas ??? About to give up..
Old 13 Nov 2017, 08:41 pm
Ok I read where I needed the Torx Bit and WOW was that a Pain to find a 5 point Security Torx.. 4 stores one had it.. But Im back in business. Ill submit pictures of what was wrong why it was doing the Key in ignition.. later.
Old 13 Nov 2017, 09:15 pm
rckstein's Avatar
That is mentioned in the Service Manual that it will be needed. Do you have a copy of the Service Manual?
If not, I can PM you a link where you can download a copy from my DropBox.
Old 13 Nov 2017, 09:38 pm
I have a copy of the 2001-2006 and mine is a 2008 so a lot isn’t covered.
I think after this I’m brave enough to install the cruise kit I have had for 2years
But if you have a manual for 2008 I would love it thanks
Btw this is my second pt cruiser lovingly call it the perpetual turd 😋😜
Old 13 Nov 2017, 10:02 pm
rckstein's Avatar
PM sent
Ignition Tvio Welcome New PT Cruiser Members 24 28 Sep 2017 03:41 pm
Key in Ignition SilverPTMom Tech & Performance Forum 3 25 May 2016 02:26 pm
Ignition Mcgoats General PT Cruiser Discussions 8 06 Aug 2014 04:06 pm
%#^&&* ignition key!! wompus General PT Cruiser Discussions 19 02 Aug 2013 04:57 pm
Ignition Key uskeith Tech & Performance Forum 7 17 May 2008 05:45 am
