Differential bearings replacement
Like Tree11Likes
  #11 (permalink)
Old 04 Dec 2018, 02:20 pm
rob302's Avatar
Default Re: Differential bearings replacement
Originally Posted by Sinbad View Post
Go on then... what was it..?
there was a nut loose behind the wheel.
Sinbad likes this.
  #12 (permalink)
Old 04 Dec 2018, 02:43 pm
Sinbad's Avatar
_________________________________________
'07 2.2 CRD
Bollocks to Brexit
  #13 (permalink)
Old 04 Dec 2018, 03:00 pm
rckstein's Avatar
You think we will have to wait another year for the answer
rcktpwrd likes this.
'06 Touring Edition NA Automatic
160k Miles / Electric Blue Pearl
USMC '82 - '93
  #14 (permalink)
Old 04 Dec 2018, 04:40 pm
I just replaced the Differential bearings on my Getrag unit when i swapped in the LSD. My local trans shop was also able to find them. I found them from a online supplier MROsupply.com I used the actual bearing number on the bearing, don't forget the races as well, they wear as a matched set.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
  #15 (permalink)
Old 04 Dec 2018, 09:56 pm
Sorry guys just been working a lot, sometimes just too lazy and too tired to finish a sentence...
So apparently I tried everything and changed everything I could imagine or could think of except diff bearings. The noise would be worse at between 20-45 miles an hour and didnít sounded like anything else I could think of. I bought new tires on amazon and took it to the shop, they pulled one off ( the one that had a slow leak) and I saw liquid inside. And it hit me that months ago I put foam in it to seal the leak, but I guess after long time it turned to liquid and would make that slushing/woshing noise till centrifugal force would disparse it evenly against the walls... I couldnít wait to put second tire on I had to drive and see, that was it - just fluid inside the tire.. on another note, I got new axels and wheel bearings that I didnít need 😂
  #16 (permalink)
Old 04 Dec 2018, 11:21 pm
Mystery solved. Weird. We should make that a "rule of thumb". Check the most recent fixes first. Don't feel too bad, my Oldsmobile's trunk is full of replaced parts that didn't fix the problem. Occasionally comes in handy.
808PTcruiser and Sinbad like this.
Differential Bearing mooner General PT Cruiser Discussions 0 09 May 2015 09:36 pm
01 Limited Automatic/Differential Question Sarasmiles Tech & Performance Forum 20 27 Jun 2012 03:18 pm
Differential Saaver Tabs How-To T-350 5spd UptownSport Tech & Performance Forum 0 22 Jan 2012 12:48 pm
Differential gaskit leak oldcoach General PT Cruiser Discussions 1 21 Oct 2011 08:48 am
Differential? DeVinyl Tech & Performance Forum 5 21 Nov 2010 02:49 pm
