Strange Issue With My PT Cruiser
Like Tree2Likes
  #11 (permalink)
Old 21 Nov 2017, 07:44 pm
Default Re: Strange Issue With My PT Cruiser
myckee, I had the belt replaced at around 80 000 and it looks good.
chuz sorry for the confusion...the car doesn't start. It cranks but it's not starting
  #12 (permalink)
Old 22 Nov 2017, 12:50 am
sanatanadharma's Avatar
Fuses will cause your problem!!!!!!!!!!
Check
Dash fuse #11 (10 amp)
Fuse #13 (20 amp) in the under-hood PDC
Originally Posted by 4leafclover View Post
My PT Cruiser is 2005, NON-Turbo, 144 000 miles...it drove fine since 2006, no major issues. Two days ago ... the engine was only cranking, wouldn't turn over. ...-just cranks, not turning over.
Can somebody give me any ideas what else to look for?
I appreciate any help!
  #13 (permalink)
Old 26 Nov 2017, 06:46 pm
Checked the fuses, they are all OK. I finally found some time to replace the oil pressure sensor, however the car still didn't start
I bought all the parts(camshaft sensor&oil pressure sensor) at Autozone, BTW
  #14 (permalink)
Old 26 Nov 2017, 08:04 pm
I would suggest resetting the engine trouble codes with a scan tool and see what new codes are triggered.
  #15 (permalink)
Old 06 Dec 2017, 08:24 pm
It looks like it is the timing belt. It's missing some teeth. I am trying to replace it but not too many DIY videos out there.
  #16 (permalink)
Old 06 Dec 2017, 08:35 pm
We have 5 or 6 HOW TO instructions for changing of the timing belt in our Tech & Performance section including some tips and tricks that might help. Here's the link to that section...
HOW TO's
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
  #17 (permalink)
Old 06 Dec 2017, 10:26 pm
rsrocket1's Avatar
Mandatory watch (all 7 parts)
After you watch a pro do it, you can pick up a few hints on videos like this. Plus you'll know what to do and what not to do
JDK52 likes this.
Strange timing belt failure and other strange symtoms StephenB Tech & Performance Forum 5 28 Mar 2016 12:57 pm
Very Strange Electrical Issue Please Help! Hans2112 General PT Cruiser Discussions 4 21 Nov 2015 10:35 pm
strange idle issue dalandon Tech & Performance Forum 8 08 Apr 2015 10:25 am
01 pt cruiser strange overheating stixboy General PT Cruiser Discussions 11 15 Jun 2010 12:07 pm
Strange AC issue, please help. Montollio Tech & Performance Forum 6 24 Jun 2008 09:34 pm
