ABS & TRAC lights on
Like Tree8Likes
  • 3 Post By niggle
  • 2 Post By niggle
  • 3 Post By niggle
Old 22 Nov 2017, 02:18 pm
Default ABS & TRAC lights on
So as I mentioned in my newbie post these lights are on permanently on my '02 Street Cruiser. This is a fail for the UK MoT annual safety test, and the car is overdue for an MoT so cannot be used on the public road until cured. I got an auto-electrican to check for the ABS codes, but neither of his readers could get the codes. I had previously tested the resistance of the wheel sensors as advised on another forum, and as they were all very close to each other at just over 5kOhms I though they must all be good. However I then stumbled on this Youtube clip which says that resistance testing is not helpful, you have to measure voltage output from the sensors as the wheel turns. I tried this and one sensor is not cycling like the others do between about 0.9 and 1.8V. I have ordered a replacement so will let you know how this goes once installed.
Old 22 Nov 2017, 02:29 pm
Handy_Cruiser's Avatar
Default Re: ABS & TRAC lights on
Good going. You may have solved this one.
Most of the lower-end OBDII readers don't read ABS codes. Often you have to get a little bit more expensive one to get that feature. I'm surprised your auto electrician didn't have one that could do it. But hey, there's nothing you can't learn to do yourself watching YouTube.
Old 22 Nov 2017, 03:06 pm
The guy is mostly retired, he was recommended to me by my local trusted garage, and when I met him I recognised him as the father of a lad my youngest went to primary school with about 12-13 years ago. He had two Autel readers, one was an ML5?? and the other was an ML619, which I was told by Autel won't read the pre face lift Chrysler ABS codes, but I didn't say anything as he was trying to do me a favour at no cost. Autel said their ML629 will do the job, but for the moment I am not going to order one as they are 83, will see how the 25 wheel sensor does first. One thing I noted was that the sensor that failed (the front right) is the only aftermarket one on the car, so if the new one fails in a short time I think I will try a genuine one next.
Old 24 Nov 2017, 12:58 pm
Update: new sensor arrived yesterday but it was raining hard until this afternoon (I do have a garage but it is stuffed full with bicycles and lawnmowers...). Sensor fitted a couple of hours ago and on a test drive straight after the ABS and TRAC lights went out, and stayed out, after about 3 seconds of forward motion Total cost to put the ABS light out was 27, a tad over $30
Anyway, just wondered if it would be a good idea if that Youtube clip I posted could be added as a sticky, the voltage method is really quite easy to do, saves paying for code reading if you only have a bad sensor and worked for me when the resistance test told me nothing, actually mislead me.
Old 24 Nov 2017, 04:28 pm
MJKnight's Avatar
Good info..
the dash on both pts are
lite up like a Christmas tree.....
Abs and trac lights on Denvercruiser General PT Cruiser Discussions 50 28 Nov 2016 06:28 pm
Trac, ABS, and brake lights on kboone Tech & Performance Forum 0 27 Nov 2015 03:39 am
Trac off and ABS lights Myoldptc General PT Cruiser Discussions 4 05 Oct 2015 02:18 pm
ABS & Trac lights ON guitarman137 Tech & Performance Forum 5 07 Feb 2013 10:59 pm
Swapped my PT, but have a new problem... ABS & TRAC OFF Lights on.... stek2008 General PT Cruiser Discussions 7 16 Dec 2010 08:27 am
