My 2007 pt cruiser has a weird problem. When the engine is cold (overnight), the engine will crank but won't start in the first try. It will start in the second try. However, when engine is hot, it starts fine. Also, the check engine light is not on. The problem starts this Oct. when temperature starts to be low in the morning (32F). But because the car start eventually, the battery should be OK, right?
The engine cranks and it will start eventually, so the starter should be fine, right? I tried to turn the key to ON without starting the engine and waited for a few seconds, the engine still could not start in the first try but will start in the second try. So I think the fuel pump and fuel filter should be fine, too. I did an oil change this Sep. and the car past the NY state annual inspection this Oct. So what do you think is wrong? I'd like to take the car to a mechanics for an inspection. However, it seems that it is really hard to repeat the problem right away, and I don't want to leave the car there for a few days. I appreciate it very much, if anyone could point me to a possible cause. Thank you very much. Last edited by TDFF; 26 Nov 2017 at 07:22 pm. |
![]() Quote:
I tried this waiting for about 10-20 seconds, but I still need to start the engine twice. |
![]() Quote:
![]() Your PT sounds like it has the same problems as mine when the fuel pump was going out. After sitting overnight, it would have a long crank on a cold engine. But after starting and repeatedly shutting down and restarting numerous times throughout the day, it would run fine. Then hard to start again the next morning. There is no fuel filter and you can have a fuel system pressure test done. Which I did have and the fuel pump was supplying enough pressure and the fuel injectors were not leaking down. Apparently there is a check valve in the fuel pump that was not holding the system pressure overnight but slowly leaking down. Had the fuel pump replaced 08/14 and has fired up within a few seconds ever since. ![]() When you get a chance please go to Welcome New PT Cruiser Members - PT Cruiser Forum and create an intro thread. ![]() |
![]() Quote:
Thank you for your reply. Then do you have any idea how to check if the pump is failing? |
When you turn the key on, the pump only runs about three seconds. Waiting longer doesn't build any extra pressure.
I see. Thank you very much. I will find some time to let the pump be checked and replaced.
![]() Quote:
If you don't have a fuel pressure gauge I would suggest turning the key to the "On" position, wait 10 seconds, turn the key off for 5 seconds, and then back to the "On" position several times to see if it helps build up the fuel pressure. Then try starting it to see if it starts the first time. Have you checked for engine trouble codes with the OBDII Scan Tool?
If at First You Don't Succeed - Try, Try Again Last edited by ptcruisersteve; 26 Nov 2017 at 08:50 pm. |
![]() Quote:
I remember a few months ago when one of the cells in my battery was going bad it took two times to start the engine. After I replaced the battery I didn't have that problem anymore. Try taking it to an Autozone or an auto parts store where they will test it for free.
If at First You Don't Succeed - Try, Try Again |
Thread Tools | |
Display Modes | |
2007 Cruiser wont start when its hot outside | randycooley1980 | General PT Cruiser Discussions | 6 | 27 Jul 2017 06:59 pm |
2007 PT Cruiser won't start | bacoffey | Tech & Performance Forum | 10 | 15 Oct 2015 08:46 am |
2007 diesel cruiser turns over but wont start after front end shunt | guitarman | Tech & Performance Forum | 0 | 07 Jan 2013 06:37 am |
2007 PT Cruiser Overheated now wont start!! | kbryant | Tech & Performance Forum | 15 | 25 May 2012 03:55 pm |
Pt Cruiser 2007 Does not start | Selim | Tech & Performance Forum | 2 | 06 Feb 2010 09:24 pm |
