PT IS USING AT LEAST A QUART OF OIL A DAY & NOT LEAKING
Like Tree3Likes
  • 1 Post By rob302
  • 2 Post By rsrocket1
Old 15 Dec 2017, 08:40 am
Default PT IS USING AT LEAST A QUART OF OIL A DAY & NOT LEAKING
Thanks in advance for any help you can offer. I have a 2005 Cruiser n I bought it a few months ago used. The owner did tell me it may need a new OIL SENDING UNIT..(sorry if I said it wrong) I tried looking online to purchase one but wasn't sure wat exactly it was called. It isn't leaking on the ground and I was hoping you guys could offer a few things I could check out.
Old 15 Dec 2017, 09:18 am
rob302's Avatar
Default Re: PT IS USING AT LEAST A QUART OF OIL A DAY & NOT LEAKING
How many miles are you driving a day to lose the quart?
Can you smell it burning?
Any smoke out the tailpipe or hood?
NitroPT likes this.
Old 15 Dec 2017, 12:14 pm
rsrocket1's Avatar
Also check the PCV Valve. Simple job, it's next to the ATF dipstick near the air box and battery (not the front, that's the oil dipstick).
Remove the hose, unscrew the PCV valve and shake it. It ought to rattle. If it doesn't, replace it or if you've never replaced it, replace it anyway. It's only $4.50 at an auto parts store.
soyomb and Handy_Cruiser like this.
Old 15 Dec 2017, 12:49 pm
Also check your air filter.
Tags
oil consumption, oil sending unit, pt cruiser
Lowest priced atf +4 trans fluid per quart? Shelby5041 Tech & Performance Forum 20 15 Nov 2017 06:22 pm
2002 PT Cruiser going through a quart/week oil and coating back of car in oil residue Hippietank Tech & Performance Forum 12 15 Jun 2016 08:22 am
What is leaking??? ddres0605 General PT Cruiser Discussions 5 14 Mar 2016 09:47 am
Where is the 5th quart of oil? briancpearce Tech & Performance Forum 20 20 Aug 2010 07:45 pm
Leaking oil cap? CreepyPT Tech & Performance Forum 3 29 Oct 2009 12:16 am
