Need Help
Old 18 Dec 2017, 06:26 am
Red face Need Help
Have 2005 PT Touring 150,000 miles. Have had since new and maintenance up to date. Have taken very good care of car. My problem is car idles great no problem, then out of the blue, was stopped at red light then the car started cutting out no power when acceleration was applied jerking, skipping but never died. Would have to go to 2nd gear at 10 mph, 3rd at 20 mph, 4th at 25-30 and 5th at 40. When I would finally get to 5th gear car would then run smooth as long as I would not go over 60 mph. Just got car fully serviced 4 days ago from my trusted mechanic. What the heck is going on... PLEASE HELP!!!!
Old 18 Dec 2017, 09:20 am
Default Re: Need Help
Sounds like you need to take it back to "trusted mechanic" to me. Was it running okay before he worked on it? Get the codes read first at Autozone or whatever parts store you're close to and take the list with you. Post the codes here too. MAYBE your catalytic converter is clogging up. IDK, I'm NOT an ASE Certified Master Mechanic.
Old 18 Dec 2017, 09:53 am
rckstein's Avatar
Welcome to the forum
"Fully serviced" what was done?
When you get a chance, please go to Welcome New PT Cruiser Members - PT Cruiser Forum and create an intro thread
Old 18 Dec 2017, 11:02 am
Azrak's Avatar
Take it back to your mechanic. There are such things as coincidence, but this happening this way after just being serviced, in any way, should point you to this.
2005 Touring Convertible - 2.4L I4 DOHC 16V Turbo Engine - 4-Speed Automatic Transmission.
LT. Almond Pearl Metallic Clear Coat - Black Cloth Top.
Cloth Low-Back Bucket Seats - Dark Slate Gray.
Old 18 Dec 2017, 12:07 pm
Welcome to the forum.
You should introduce yourself and tell us about your Pt Cruiser.
WELCOME and Forum Rules
From the information you have given so far you might be only running on 3 cylinders. If your check engine light is on get the engine trouble codes at an auto parts store that offers it for free and post what they are. See if one of the spark plug wires is not connected to the spark plug.
It might be worth it to buy your own OBDII Scan tool to see if the problem might be something you can repair yourself. This way you have done the diagnosis and know more about what the problem might be.
Old 18 Dec 2017, 01:29 pm
Red face Re: Need Help
Ok, went to welcome post and introduce myself.. sorry didn't know I was supposed to do that..
Car is flashing codes P0344 and P0441. Camshaft sensor and evap purge solenoid.
Old 18 Dec 2017, 01:55 pm
P0344 - Camshaft Position Sensor Circuit Intermittent
Possible Causes:
1. Wiring harness fault 5v supply circuit open or shorted to ground
2. Tone wheel/pulse ring is damaged or corroded
3. Camshaft Position Sensor has failed
4. Camshaft Position Sensor signal circuit is open, shorted to ground
5. Camshaft Position Sensor ground circuit is open
6. PCM has failed
If you have a voltmeter unplug the camshaft sensor plug and see if you have 5 volts going to it. If you don't have 5 volts check the wiring going to the Camshaft Sensor. If the 5 volts is good and you decide to replace the Camshaft sensor make sure you get an OEM Camshaft Sensor. Some members have had intermittent problems with aftermarket sensors. The Camshaft sensor is very easy to replace and easy to get to. Do not over torque the camshaft sensor as they crack easily.
Old 18 Dec 2017, 02:16 pm
P0441 - EVAP Purge Flow Monitor Fault
Possible Causes:
1. EVAP purge solenoid vacuum line loose, leaking or restricted
2. EVAP purge solenoid stuck leaking, stuck open or stuck closed
3. EVAP purge vacuum line to canister leaking or disconnected
4. EVAP canister leaking, damaged or has failed
I would suggest resetting the DTC's and see if it comes back.
If the codes come back I would suggest checking for any vacuum leaks first. The natural vacuum leak detector (NVLD) and the purge solenoid are mechanical electrical valves. If no vacuum leaks I suggest you check the purge solenoid and the wiring going to it.
If the purge solenoid works properly I would suggest checking the NVLD wiring going to it and if that is okay check the NVLD.
Old 19 Dec 2017, 02:05 am
Thanks for all the information. I will try these and go from there. Will keep you updated and again Thanks.
