Starting problems
  • 1 Post By rob302
Old 27 Dec 2017, 04:26 pm
Default Starting problems
Itís an 05 non turbo 178k miles. Timing belt broke had never been changed before. After replacement and water pump everything lines up. All timing marks are good from hand cranking. When trying to start the starter goes but the motor doesnít crank. As in the cams and crank donít move when the starter goes. Starter makes a whining sound not a clicking. Any advise?
Old 27 Dec 2017, 04:32 pm
rob302's Avatar
Default Re: Starting problems
maybe the bendix is just stuck. did you try tapping on the starter while someone bumps the key?
Old 27 Dec 2017, 05:28 pm
Welcome to the forum.
When you have a chance please introduce yourself to the forum.
Is the engine still apart or is everything back together?
I would suggest checking to make sure all the wires going to the starter are connected and making good contact. Hard to believe the starter would go bad right after the replacing the timing belt. Was any of the wires going to the starter removed. If so some members have reinstalled the starter wires in the wrong starter post.
Old 27 Dec 2017, 06:32 pm
I'm inclined to agree with Rob. I'd definitely try whacking the starter and see what happens. A car with that many miles on it wouldn't surprise me if the starter is shot.
Old 31 Dec 2017, 09:27 pm
NNNnnooo. Modern starters use permanent magnets that will crack if the field housing is struck too hard. The will permanently damage the starter.
Striking the starter in the old days worked to jar stuck / nearly worn down brushes in an attempt to make enough contact for one last go round. This was possible due to wound field coils that could tolerate striking.
If the starter motor spins but the engine does not, the starter drive one way clutch is slipping.
Old 31 Dec 2017, 10:02 pm
rob302's Avatar
Still works for me
I have beat a starter to failure, but it was a lot of pounding. Tap tap tap still works for a few months, no?
chuzz likes this.
Old 31 Dec 2017, 11:31 pm
Azrak's Avatar
I agree with rob32 and chuzz, taking into account the limited clearance on a PT you might need to be a magician or contortionist in order to whack a starter on one hard enough to bust up the magnets.
2005 Touring Convertible - 2.4L I4 DOHC 16V Turbo Engine - 4-Speed Automatic Transmission.
LT. Almond Pearl Metallic Clear Coat - Black Cloth Top.
Cloth Low-Back Bucket Seats - Dark Slate Gray.
Old 01 Jan 2018, 07:55 am
Make sure there is a full charge on the battery or and use a charger with a boost .
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 01 Jan 2018, 08:52 am
A long bar works wonders when dealing with limited clearance.
Regardless, if the starter motor spins, the brushes are making contact and the starter solenoid is moving. In cold weather grease in the starter drive gets stiff and the one way clutch can slip.
CORRECTION BELOW
The spare starter I have is made by Mitsubishi not Bosch as I had previously stated. I'm not sure if these suffer the same gear train breakage as the Bosch units. It looks like a Bosch NEON starter would bolt up so there is a chance it was swapped at some point.
The starters on what looks to be pre 03 NEONS are made by Bosch, they are an inline gear reduction type that uses a planetary gear set. The ring gear can split ( plastic on lower power starters ) leaving the starter motor to spin but the drive won't.
Last edited by 06_PB6_TOURING; 01 Jan 2018 at 12:11 pm. Reason: Starter brand incorrect
starting problems sgmex General PT Cruiser Discussions 8 02 Oct 2015 04:04 am
Starting Problems 1Conundrum Turbo Performance 6 07 May 2014 11:34 am
Starting problems wargamer6 General PT Cruiser Discussions 17 18 Nov 2010 08:41 pm
Starting Problems 2003gt Tech & Performance Forum 4 21 Apr 2009 05:49 am
Problems Starting hhomer PT Cruiser Convertible Forum 0 29 Aug 2004 08:25 pm
