Correct PCM Mounting Bracket Bolt???
  • 1 Post By rckstein
Old 30 Dec 2017, 05:49 pm
Default Correct PCM Mounting Bracket Bolt???
So, I've navigated the infamous P0601 code and replaced the PCM with a remanufactured PCM out of Florida. The fix seems to have worked, but it turns out the new PCM came with the correct mounting bracket that wasn't on the old PCM that someone had previously replaced. Now I need to determine the correct bolt size to mount the mounting bracket onto the metal tabs from the firewall.
Anybody know the correct bolt size? Or, where I can find that bit of info??
Thanks in advance for the answer and thanks for being the resources I needed to even get this far.
Oh, by the way, it's a 2001 PT Cruiser.
Cheers
Old 30 Dec 2017, 08:22 pm
rckstein's Avatar
Default Re: Correct PCM Mounting Bracket Bolt???
Welcome to the forum
From what I can find in the Parts Catalog, it should be:
MOPAR 06505900AA
SCREW, Tapping Hex Flange
Head, M6.3 x 1.81 x 19.00, Engine Controller Mounting
When you get a chance, please go to Welcome New PT Cruiser Members - PT Cruiser Forum and create an intro thread
Handy_Cruiser likes this.
Old 31 Dec 2017, 04:44 pm
The screw size "SCREW, Tapping Hex Flange Head, M6.3 x 1.81 x 19.00" struck me as odd for a metric screw, so I converted it into inch base size:
M6.3 = .248" = 1/4"
1.81 = 14 threads per inch
19.00 = .748" = 3/4"
So I'd say that's a 1/4-14 x 3 /4 hex washer head self-tapping screw.
If you Google "1/4-14 x 3/4" you'll get lots of hits, most look like self-drilling types. I checked my Cruiser they're not self-drilling, however I suspect the self-drilling ones would work. The stinker is that you usually have to buy these types of screws by the pack. You could try a hardware store, you might get lucky. (Note: standard 1/4" sheet metal screws have a coarser thread.)
The other option is hitting a junkyard and pulling the screws off a Cruiser.
Tags
mounting bolt, pcm
Mounting Bracket for lower exhaust manifold? ptcruizin Tech & Performance Forum 1 10 Jun 2015 04:39 pm
Caliper mounting bracket bolt size Ptcruisershort General PT Cruiser Discussions 2 18 Apr 2012 12:08 am
MT mounting bracket, old clutch plate TheRed Classifieds: Want To Buy 1 05 Aug 2011 04:44 pm
License Plate Mounting Bracket Tallulah Exterior Accessories Forum 4 19 Apr 2010 05:25 pm
Front licence plate mounting bracket 01 meredog Exterior Accessories Forum 4 08 Jul 2007 10:01 am
