Steering rack leaking
Like Tree2Likes
  • 1 Post By rckstein
  • 1 Post By Jdhaulr1
Old 03 Jan 2018, 11:10 am
Jdhaulr1's Avatar
Default Steering rack leaking
Anyone know of any how-to videos on steering rack replacement?
Old 03 Jan 2018, 11:14 am
Default Re: Steering rack leaking
You might check youtube. I did mine by myself in about 4 and a half hours. It was a pain in the neck. It's better if you have a helper. Especially to guide the steering connector back through the floorboard opening. That's where I had the problem. Mine went under the floor insulation and the firewall and I didn't realize it until I tried to fasten everything on the drivers side. Took me about an extra half hour because of that oversight.
Old 04 Jan 2018, 12:35 am
Jdhaulr1's Avatar
Thanks for the reply, I have searched YouTube and haven't found a video on this subject. Does the Kframe have to be removed? Or perhaps removing the Kframe make the job easier? My car is a GT so there isn't much room to work. I appreciate the info!
Old 04 Jan 2018, 07:09 am
rckstein's Avatar
Viewing some of your previous posts, I believe that you have an '03?
Do you have a copy of the Service Manual?
If not, then you can download a copy of it from this link from my DropBox:
https://www.dropbox.com/s/8ykx6mdsck...4CPTC.pdf?dl=0
Section 19-28 is about the steering rack. On page 19-31 there is a special note about scribing the front suspension crossmember to the vehicle before removal.
Handy_Cruiser likes this.
Old 04 Jan 2018, 09:48 am
Jdhaulr1's Avatar
Thank you Eckstein! Yes my car is an 03, I appreciate that inforation! 👍I will download the service manual you provided, I've been under my car a few times the last couple of weeks keeping an eye on the leak trying to figure out where it's coming from, it's definitely the right seal, I hate oil leaks! Haha! Thank you!
Old 04 Jan 2018, 09:49 am
Jdhaulr1's Avatar
Sorry, that was supposed to say rckstein! Darn autocorrect!!
rckstein likes this.
Old 04 Jan 2018, 11:27 am
Hey JD, I don't remember what all I had to take loose. I've had two brain surgeries and my short term memory doesn't work very well. I DO remember having to take the sway bar out of the way, and that's about all I recall. Except it was hot and so was I by the time I got done. If you just take your time, I'm sure you can do it too. Mine was leaking on the right side too. Damned internal seal of some kind.
Best Trailer for towing/rack and pinion leaking CruiserinCA General PT Cruiser Discussions 8 03 Jan 2017 02:13 pm
Leaking Rack chuzz General PT Cruiser Discussions 31 08 Aug 2016 08:43 am
power steering cap is leaking cwj General PT Cruiser Discussions 1 21 Jan 2013 04:44 pm
Power steering rack leaking - control arms harrym Wheels, Tires, Suspension 0 18 Oct 2011 06:52 pm
HELP aftermarket mopar roof rack leaking through seals Dimitry Exterior Accessories Forum 2 23 Jul 2010 09:46 pm
