2005 Turbo issue
  • 1 Post By rob302
Old 03 Jan 2018, 12:29 pm
Default 2005 Turbo issue
New to site and I'm sure this is covered somewhere.
just found out my daughters 05 PT turbo failed. Dealer quoted $2500.00 to replace.... Question, how hard is it to replace a turbo. I have a pretty mechanical knowledge, tools and a cold garage.. thinking about doing it myself. Dealer told me it was about 90 hours of labor?
Thanks
paul
Old 03 Jan 2018, 12:34 pm
rob302's Avatar
Default Re: 2005 Turbo issue
this shows 5.9 hours labor, and 2120 for the turbo.
check here, you can do it for 1/10th the cost (:
HELP!!! Time to replace the turbo!!! :(
Handy_Cruiser likes this.
Old 03 Jan 2018, 12:39 pm
Handy_Cruiser's Avatar
EDITED:
+1
Didn't see Rob's link to the current thread on this at first. Read that as a primer and then ask your follow-up questions. We are here to help.
Old 03 Jan 2018, 09:16 pm
The turbo is part of the exhaust manifold. Have a look on rockauto.com they have 100% new kits. It is also possible to get just the center section and reuse your exhaust manifold and air inlet side.
I haven't done a PT but other than dealing with stuck nuts, it isn't a difficult job. I'd probably order new studs between the cylinder head, I've seen too many exhaust studs break across many models.
What specifically did they say failed in the turbo? What were the symptoms?
Old 04 Jan 2018, 07:56 pm
Thanks for the replies. Guessing the internal seal went bad... car started to puke a ton of smoke out the exhaust.... I checked PCV system... no blockages there
Old 05 Jan 2018, 06:24 am
OK. Don't continue to drive it, at minimum the cat will be coated in carbon that might burn off. At worst the cat will be clogged / damaged and need $$$ replacement.
5spd. Issue 2005 GT TopGunRMNP General Turbo Discussions 5 22 Nov 2017 01:12 am
2005 PT Vert N/A 5-spd possible tranny issue Dill General PT Cruiser Discussions 11 12 Sep 2017 02:27 pm
2005 PT Convertible shifter issue VermontBob General PT Cruiser Discussions 0 01 Dec 2016 07:08 am
2001 & 2005 cooling fan issue ptcruiserdad Tech & Performance Forum 12 03 Jul 2011 07:26 pm
Issue with my 2005 PT Cruiser Sharie Tech & Performance Forum 10 18 Feb 2011 01:55 pm
