Air Bag light stayes on
  • 1 Post By ptcruisersteve
Old 04 Jan 2018, 03:23 pm
Default Air Bag light stayes on
Just finished a valve cover gasket change and started the car and air bag light stays on, disconnected battery and did a reset, didn't help, anything in the engine compartment that would cause this to happen, something I might have done, I have no chiming bell as I've seen in other posts will driving the car
Old 04 Jan 2018, 04:20 pm
Default Re: Air Bag light stayes on
I would sugggest checking to see if the wires for the air bag sensor got disconnected going to the front of the Pt Cruiser. Make sure you disconnect the battery first and know what you are doing. This can be an expensive mistake if the airbag goes off.
rob302 likes this.
Old 04 Jan 2018, 04:25 pm
rob302's Avatar
steve i'm pretty sure the PT has no crush sensors, only an inertia module inside the cabin by the parking brake handle
edit.. i see there are two in front
Old 04 Jan 2018, 07:12 pm
Handy_Cruiser's Avatar
On some PT's there's a ground wire that attached to an electrical noise suppressor that fastened to one of the valve cover bolts. If left off, it can cause some grounding issues. If me, I'd check this and all other wiring around the valve cover. If this only started after the valve cover gasket change, there is a fair possibility that your problem is related one way or another.
Old 04 Jan 2018, 07:32 pm
Thank you all , I check it out
Old 06 Jan 2018, 06:16 am
If a code is set for the air bag, you may have to get a mechanic with the appropriate scanner to clear the code. I had to replace the clockspring on my wife's car. The air bag light and codes were persistent, disconnecting the battery didn't clear them. I ended up going to a body shop where they checked and cleared the codes. The shop owner said "no charge", I slipped the mechanic a $20 and everybody was happy. Much cheaper than having the dealer do it.
Old 06 Jan 2018, 08:06 am
I think it's fixed, the light is turning off when started. I found a video of how to reset the instrument panel and tried that and now everything is working
Old 22 Feb 2018, 04:26 pm
Do you have a link to the instrument panel reset video?
ABS Light, Parking Brake Light, Traction Control Light kupothechocobo General PT Cruiser Discussions 9 28 Feb 2017 01:56 pm
Left Side Break Light / Blinker / Reverse Light MaxJoseph Tech & Performance Forum 6 07 Nov 2015 05:18 pm
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Mork's Tail Light and Reverse Light Tint Progress Morkeste Exterior Accessories Forum 30 23 Jun 2011 12:20 pm
