Turn the key to the accessory position and see if the blower / windows work. I'd need to see a wiring diagram for the ignition switch but I suspect it is failing.
Turning the key back and forth a bit might help. I'd also put a test light on a fuse that gets power from the accessory circuit and see what happens. In instances like this, I've back fed power the supply side of a fuse to see if the circuits are intact. If power is fed to the load side of a fuse and the total loads of other circuits on the supply side are higher than the fuses rating, the fuse may clear so pulling the fuse first is a better strategy. |
Loving all these suggestions guys - thanks again.
Temperature is supposed to get above freezing next week (heat wave coming !) - can't wait to get out and give these ideas a try. Mark. |
This sounds like a good step to try.
Cars: 2015 Fiat 500 Abarth in Rosso RED (MAD FIAT) 2015 Fiat 500 Turbo in Granito Lucente (Proyecto Estupido) 2003 PT Cruiser GT in Boring Beige (RIP) |
Partial Update ....
Damn near froze my fingers off, but managed to check all the fuses and they are all good. Played with the ignition switch and got no results either. However, did have a look at the ground terminals behind the air intake box. They are covered in a nice even coat of green, so they are obviously suspect. Will give those a good cleaning when the feeling comes back in my fingers ! Mark. |
![]() Quote:
GROUND LOCATION FIG. G100 (Gas) Left Front Engine Compartment 2, 5, 6 G100 (Diesel) Below Passenger Seat 7, 48 G101 At Battery Tray 5, 6, 7, 18 G102 Left Fender Area 1, 14, 16 G103 Left Fender Area 1, 14, 16 G104 Right Fender Area 9, 10, 11, 17 G105 Left Front Inner Fender 13, 14, 16 G106 In T/O for Powertrain Control Module 25, 26 G200 Center Rear of Instrument Panel 31 G201 Center Rear of Instrument Panel 28, 33 G202 Left Kick Panel Near T/O for Airbag Control Module 36 G203 Center Rear of Instrument Panel 31 G204 Left Kick Panel 31 G300 Left Rear Quarter 46, 47 G301 Right Rear Quarter 43 G302 Upper Left Rear Cargo Area N/S
If at First You Don't Succeed - Try, Try Again Last edited by ptcruisersteve; 14 Jan 2018 at 04:10 pm. |
![]() Quote:
On mine the ground wires corroded away from the eyelet. Ended up putting 3 or so wires per eyelet and recrimping, there are about 20 ground wires between both sides. Be sure to scrape the wires clean and check the grounds on the passenger side inner fender area as well. Even if doesn't fix the blower issue, it will save you from other ills like no fuel pump. headlights, turn signals and more since everything not inside the car uses these grounds. |
Thread Tools | |
Display Modes | |
Fuse box bad? | 06_Cruiser | Tech & Performance Forum | 3 | 02 Sep 2013 02:00 pm |
no Fuse problem and not iod fuse | ptcarter | Tech & Performance Forum | 24 | 09 Jul 2013 03:21 am |
Fuse Box -- Need Help | PtPtPt | Tech & Performance Forum | 12 | 22 Jun 2013 09:43 am |
HELP with Wiring Fuse 7 (No feed to fuse) No A/C, Electric Windows, Rear fogger??? | ptcruisershoreham | General PT Cruiser Discussions | 3 | 08 Mar 2011 08:06 pm |
No fuse??? | Ironman | Tech & Performance Forum | 0 | 07 Dec 2009 06:30 pm |
