PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Tech & Performance Forum (http://www.ptcruiserlinks.com/forum/tech-performance-forum/)
-   -   Would This Be A Fuse Or .... ? (http://www.ptcruiserlinks.com/forum/tech-performance-forum/65441-would-fuse.html)
markroach 06 Jan 2018 08:30 am
Wife just called - her 2002 NA 2.4 automatic is having a problem ....
The airbag light is on and the power windows and heater blower are not functioning. Maybe other items as well, but that's what she noted.
Could this just be a bad fuse ? Don't have the manual in front of me and what I can find online is rather vague as to exactly what each fuse controls.
She's afraid to drive it home for fear of not makiing it, so I'd like to roughly know what I'm in for when I get there. It's super cold here right now.
Mark.
(Don't worry, she's not stuck outside .... the wife that is. ;) )
06_PB6_TOURING 06 Jan 2018 10:12 am
Re: Would This Be A Fuse Or .... ?
Don't know about the fuses but look at the pic in post 12
http://www.ptcruiserlinks.com/forum/...raining-2.html
And my posts 5 and 9 here where I talk of ground issues that occurred on my 06.
http://www.ptcruiserlinks.com/forum/...shut-down.html
ptcruisersteve 06 Jan 2018 11:12 am
Check fuse # 3 (40 amp) in the power distribution center (PDC) under the hood. It is a common feed to the fuses and circuit breaker for all three systems that you mentioned. Check the fuse first.
The Power Window Switch and the A/C Heater Control switch share the same ground circuit G203. The air bag control ground is G202.
markroach 06 Jan 2018 12:24 pm
Thanks for the replies guys - Just got the car home. Will check into those when the weather warms up a bit .... don't have a garage and too damn cold outside !
FWIW, it pulls up an error code P1684 Driver 5 Line 4 - which really doesn't tell ME much.
Mark.
06_PB6_TOURING 06 Jan 2018 01:19 pm
P1XXX codes are manufacturer defined. ( RE not part of the OBD 2 standard so they vary from make to make and likely model to model. )
I'm coming up with battery disconnected in the last 50 starts ( in the 06 -10 manual )
Have you lost the setting for the digital clock ? I've seen batteries get weak enough that the cranking voltage will sag low enough to trigger an error but the car will still start and run.
The old standby was if the radio lost presets however, on my 06 the presets remain even if the battery is disconnected for weeks.
06_PB6_TOURING 06 Jan 2018 01:26 pm
More info, found this code site OBDII diagnostics. Trouble code definition for code P1684. Causes of error P1684 Also, "driver" in this context refers to an output of an electronic module. Driver 5 = chip 5 , Line 4 = 4th output of that chip.
Definition of check engine code P1684:
Chrysler/Dodge/Jeep:
The battery has been disconnected within the last 50 starts
Citroen/Peugeot:
Metering Oil Pump Position Sensor Circuit Malfunction
Fiat:
Motorised throttle(plausibility)
Ford:
GM:
Driver 5 Line 4
Honda:
Throttle Valve Return Spring Performance Problem
Mercedes:
Mini:
Electronic throttle control monitor level 2/3 - clutch torque min error
Plymouth:
Battery Disconnected Within Last 50 Starts
Volkswagen/Audi:
Contr. Unit Programming Communication Error
Volvo:
markroach 06 Jan 2018 04:54 pm
The battery hasn't been disconnected, but I did kill it trying to start it last week in this frigid weather. After having jumped it, I did note the clock was off. But, up until yesterday, the heater and windows still worked.
Mark.
06_PB6_TOURING 06 Jan 2018 06:18 pm
Given the battery was run down enough that the clock lost time, that would trigger a P1684 battery disconnected.
How cold was it the car would not start? Was it cranking but not running or would it not crank? Did you find a reason it would not run?
aelfwyne 06 Jan 2018 07:05 pm
May have the same issue myself.
Airbag light consistently on. Power windows/blower intermittently do not work. If they don't come on when I key on, I can key off and back on a couple times and they will work for the entire trip, until the next time.
Changed the fuse/breaker in the box and still giving issues.
Didn't seem to have the issue the first week I drove the car, it showed up after I put a few miles on it...
markroach 06 Jan 2018 07:16 pm
Temperature was well below zero and the car hadn't been used for three days. It cranked (barely) but not strong enough to start the car. Once jumped and running, it started every day for the following week until this problem with the airbag light and no windows / blower. Still starts and runs fine, but the problem persists.
Not driving it now because it is too cold to use with no heat. Fortunately, we do have other vehicles to use for the time being ....
Mark.
