Disabling power locks
  • 1 Post By 06_PB6_TOURING
Old 11 Jan 2018, 08:15 pm
Default Disabling power locks
The locks on both doors of my vert are locked. The remote doesn't unlock them. I can hear the click under the dash and the trunk still works with the remote. The only way to open the door is by turning the key while pulling the handle. The door opens and immediately locks. I tried disconnecting the wiring harness in the door but that did nothing. What would I have to do to just disable the power locks? I would be happy to just have them work manually as I never lock the doors anyway.
Old 12 Jan 2018, 08:08 am
Default Re: Disabling power locks
Sounds like the wire connector on the back of the lock cylinder has either come off or a wire is shorted in the harness going to it. You'll have to remove the door panel and moisture liner to get to it and see.
Old 12 Jan 2018, 05:29 pm
If you disconnected wires on the _power lock actuator_ and still have symptoms, you have a mechanical problem.
wingman55 likes this.
Old 12 Jan 2018, 08:19 pm
wingman55's Avatar
Yeah, sounds mechanical to me. I'd pull the door panel off and see if the linkage is hooked up wrong, or binding on something. You should not have to pull the handle while unlocking, and if the power is cut the lock should work manually.
2006 Limited Edition, Inferno Red, 5-speed, Bassani dual exhaust, Chrome backup light bezels, taillight trim, fuel door, antenna mount, Ventiports, door spear covers & hood prop. Silver painted lower front grille. American Racing 383 Casino wheels, w/Chrysler emblems, '02 engine cover, PT Cruiser mudguards, cargo mat. EGR Window Visors, dark gray lock pulls, dual horns, Fuzzy Dice, flames and MOPAR emblems added to front door logos, gold Chrysler emblem on rear hatch. Upgraded to RAK radio with 6 CD changer, Cassette Tape and RDS info. Name: "FIREBALL" I bought it Aug 10, 2015, with just over 35,600 miles on it.
Old 14 Jan 2018, 09:22 am
I should have mentioned that the passengers door has the same symptoms. That's what makes me think it is electrical.
Old 14 Jan 2018, 09:27 am
What did you disconnect? " I tried disconnecting the wiring harness in the door but that did nothing. "
You might have a stuck manual lock SW or the auto lock system might have failed. Either way pulling the actuator wires will revert to manual for testing. However, if the auto lock system has failed and holding a relay shut, it would be a battery drainer so the root cause must be found.
Power Locks scatgo1 General PT Cruiser Discussions 1 26 Apr 2015 08:10 pm
Power door. locks no longer locks when driving stanley Sound and Security Forum 3 10 Aug 2013 08:11 am
02 power locks dodgeing734 Tech & Performance Forum 3 05 Aug 2009 06:45 pm
Power Locks wedge22 Tech & Performance Forum 8 29 Sep 2008 11:43 am
power locks ptlvr Sound and Security Forum 3 09 Apr 2008 06:15 am
