Rad Fan Question
Like Tree4Likes
  • 1 Post By rob302
  • 1 Post By JoeX
  • 2 Post By rob302
Old 16 Jan 2018, 12:10 pm
Default Rad Fan Question
I've noticed several times since buying the Cruiser, that the cooling fan cycles way too much....
it kicks in....runs for about 4-5 seconds.... kicks out...nothing for a few seconds...repeat...over and over...
I haven't dug into it to see if it's the rad fan or condenser fan, but either way, it cycles way too much for my liking.
My first guess is a weak relay....second guess is a faulty cooling temp. sensor..
Anyone have any experience with a similar issue?
Old 16 Jan 2018, 02:15 pm
Default Re: Rad Fan Question
What year / trans / turbo or not?
Some had 1 speed and others 2 speed fan. Also, 06+ had a different control system.
Old 16 Jan 2018, 02:22 pm
02...auto... no turbo... lots of neglect by previous owner(s)..
Old 16 Jan 2018, 03:28 pm
rob302's Avatar
Does it do it when the heat is off and the knob is set to floor?
I ask because the car will use AC if it is even partially set to defrost. Defrost activates AC, even with temp set to warm. AC will turn the fan on. If the AC is low on freon, the AC will cycle on and off, as will the fan, and it could possibly do what you describe
Old 16 Jan 2018, 04:43 pm
I will try that and let you know! Thank You!
Old 16 Jan 2018, 05:50 pm
I can't help with the 02, only 06 +
Old 17 Jan 2018, 12:13 am
Tried it out, and sure enough, it was the AC fan..duh..Aaron...
Thanks for helping with a problem that I should have known the answer to...hehe
Old 17 Jan 2018, 01:18 am
_PTGT03's Avatar
it's normal... if there are only two fan speeds, the computer cycles on and off its power to control the temperature at a certain set point. this is known as ON-OFF control.
on the 2003 PT there is a variable speed fan and so the control scheme can ramp up or down the speed in order to precisely control the measured variable, through proportional integral control.
Old 17 Jan 2018, 04:50 pm
Could be related to pressure in AC system
Cycling is normal for the fan, mine did the same
rob302 likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 17 Jan 2018, 05:14 pm
rob302's Avatar
i'm with this 100%. when the refrigerant is just ssssslightly low they kick on and off like you describe, and that's why it was brought up. if you add JUST ENOUGH r134a from a refill kit to make it stop cycling, you'll be all good. don't overfill it. don't look at the gauge on the can, just add enough to make it stop cycling. i'm assuming you already knew that though and just didn't think to blame the ac in winter
:question:daytime running lights!!!:question: jrs61282 Tech & Performance Forum 10 07 Nov 2010 10:53 pm
Luggage Rack question and trailer hitch question Patrick_Dickey General PT Cruiser Discussions 5 26 Apr 2009 09:19 pm
