Gasket Failure A/T Solenoid Pack
Like Tree6Likes
  • 1 Post By rcalzadilla
  • 1 Post By chuzz
  • 4 Post By rcalzadilla
Old 23 Jan 2018, 03:33 pm
Send a message via AIM to rcalzadilla Send a message via MSN to rcalzadilla Send a message via Yahoo to rcalzadilla
Default Gasket Failure A/T Solenoid Pack
Replaced gasket for Solenoid Pack back in May 19, 2017, 104K miles. No more leaking A/T fluid but, now at 108K miles, Jan 2018 started leaking more than with old gasket.
No choice but replace it again but wonder if there isn't a better quality gasket I should buy.
I feel confident of the cleaning, torque value but, that was my first time.
Any comments would be appreciated.
2001 PT 107,000 Miles Ltd Edition
Old 23 Jan 2018, 04:34 pm
Default Re: Gasket Failure A/T Solenoid Pack
May be a restricted trans oil cooler
Old 23 Jan 2018, 05:04 pm
Handy_Cruiser's Avatar
Yep,
These don't normally leak. Chances are something else is causing the issue. It could be excess pressure from a blockage or just a piece of old gasket stuck to the facing. The gasket is easy to fix at home but a blockage will be hard to diagnose yourself.
A good and "honest" tranny shop can likely diagnose and possibly fix this in under an hour. If you compare that to your time and cost of fluid, the shop may be the smarter choice on this one.
Old 23 Jan 2018, 07:50 pm
A restricted cooler won't cause this, there is a bypass valve in the cooler circuit if the cooler is restricted. Basically, oil exits the torque converter ( where the heat is generated ) flows through the cooler then heads to the lubrication circuit.
Did you replace the upper and lower gaskets? ( see pic )
Is the spacer plate flat?
Old 24 Jan 2018, 08:11 am
Rethinking back the details of my work, I have discovered the following facts:
1-Driveway is inclined higher at the front of the vehicle and lower at the back,
in the work area.
2-Not sure if I moved the car to a level area of driveway to check and fill lost
transmission fluid. Maybe I overfilled and created the extra pressure.
3-New gasket did not leak for several months because PT is driven very little
and mostly short trips: May be why it leaks now and not originally.
Does this make sense to you guys?
Retired and limited budget so I can't take it to a shop. I'll just take it easier next time.
Very appreciative for your replies.
Handy_Cruiser likes this.
Old 24 Jan 2018, 08:44 am
That might be it.
This would likely not cause the gasket on the solenoid pack to leak. However, if you've over filled the tranny, you may be getting a leak from the o-ring on the fill tube located just above it.
Check the ATF level with the car on level ground. If over-filled, remove the excess fluid. You can siphon it out the filled tube with a small pump or aspirator ball. Or you can drop the pan, drain off and then refill to the proper level. Check that filler tube o-ring for a leak too.
However, if you are sure it's coming from the solenoid pack, then there's likely something going on with that gasket. And having a bypass valve does not preclude the chance of over-pressurization since it usually occurs when a bypass valve is the problem. But my bet is the o-ring on the filler tube.
Old 24 Jan 2018, 09:36 am
Maybe your short trip driving didn't get it up to operating temp. Go back and check your torque on the bolts. You may find them loose. A little FYI for you, when I replaced mine, I didn't have the torque values, so just "snugged" them to what I thought was tight enough. Apparently it was because mine never leaked. And because it's such a thin gasket, it's easy to bend it when installing. You HAVE to be careful with it.
Old 24 Jan 2018, 06:05 pm
in the work area.
The only thing this would do is keep some leaking fluid on the trans that would drip off when you drive it.
Over fill won't cause increased pressure.
Did you read my post 4 and look at the attached picture ?
Did you look for a leak in another or higher area like cooler lines?
The leak might be coming from the solenoid pack not the attaching gaskets.
Old 01 Apr 2018, 04:04 pm
Default Re: Gasket Failure A/T Solenoid Pack(SOLVED)
No more leaking!
1-Replaced with a new solenoid pack and gasket.
2-This time I moved all wire harnesses aside, very carefully, to insure I could place the solenoid pack in a totally horizontal position as opposed to inserting it one side first and then changing it to horizontal. This insured that the gasket would be perfectly flat, no kinks.
Thanks for all your help. Happy Easter!
Solenoid Pack Gasket Replacement Only? rcalzadilla Tech & Performance Forum 3 24 Apr 2017 01:40 pm
Transmission Solenoid Pack markroach Tech & Performance Forum 9 06 May 2012 07:00 pm
? about Trans Solenoid Pack dougk General PT Cruiser Discussions 2 29 Dec 2011 02:00 pm
'06 PT: Solenoid pack? Kell Tech & Performance Forum 3 08 Sep 2009 12:55 pm
Solenoid pack replaced, still a no go... sknight88 Tech & Performance Forum 3 19 Dec 2008 07:29 pm
