Trans wonders
Old 01 Feb 2018, 03:19 am
Default Trans wonders
So 5speed is leaking......
Previous owner had got it rebuilt. I donít think they changed the input shaft bearing/seal and itís also leaking very badly from the case halves.
I decided to check the level and found out it was very low (3qts low) pretty much empty so I know the bearings are shot. I can hear them kinda loudly imo.
So my questions are
should I rebuild it?
should I swap to a GT one?
Is there a difference from the n/a to gt 5speed?
Does your 5 speed make noise?
I tried doing some reading but couldnt really find anything specific
Old 01 Feb 2018, 04:51 am
Default Re: Trans wonders
A real rebuild on a low oil trans can get expensive if you want to get rid of worn gears. Have a look on car-part.com , this is a nation wide search of participating salvage yards. Call the yard directly as most don't reply to e mail.
Old 01 Feb 2018, 12:47 pm
rob302's Avatar
i changed the input bearing cartridge in mine. the hardest part was finding it. it's part number "SKF FC67560". if you buy it, call and have them verify it's in stock before paying.
i would open the trans and inspect it before replacing it. maybe it's something dumb, like you ground the little shift pad forks off due to no lube.
they're a fairly simple trans to play with. see mine here: i killed it.
here is the nvt350 service manual: ftp://oskin.ru/pub/chrysler-dodge/ma...8F_NV_T350.pdf
Old 01 Feb 2018, 01:16 pm
rob302's Avatar
Originally Posted by Exelbaradin View Post
S
mine made a weird whirring sound from time to time for a second or so after i would take it out of gear. not gear noise, not rpm dependent, not something i could ever identify, or anything that ever caused an issue
realistically, it's a 2003 pt cruiser. i would just fix the leaks and rock it, unless you're hearing some scary and impending doom kinda noises, like whining gears that get louder by the day
Old 14 Feb 2018, 03:55 am
thanks for the pdf, thats gonna help alot.
so yeah im starting to not like the noise my trans is making. i think it leaked out all the fluid again. gonna check later....
but just wanted to know the gt tranny doesnt have something that would be amazing to swap for like a lsd or something right?
Old 14 Feb 2018, 08:27 am
rob302's Avatar
the car doesn't really have enough power to benefit from the limited slip. mine spun both tires without it.
the GT trans is rarer(hard to find) and more expensive. the GT with a manual trans MIGHT have differently splined axles
i would get a stock replacement, or sell the car and snag a GT to play with
Old 14 Feb 2018, 01:27 pm
VsandFords's Avatar
3 quarts low?
Manual Transmission, A578 (5-SPD)..........5.1 pints
That's only 2.55 quarts total capacity.
rob302 likes this.
Old 14 Feb 2018, 03:43 pm
the only reason i thought about it was because i can get one for a decent price
Old 14 Feb 2018, 03:49 pm
rob302's Avatar
there was someone smarter than me that informed us of a difference with the speedometer speed sensor. he solved it, but you will likely never have a working speedometer again if you switch. read here and the two posts after it. Splicing manual speed sensor on an auto harness
basically it seems if you simply convert the wiring over, your speedometer will read 120 when you are going 10mph
Old 14 Feb 2018, 04:46 pm
TurboDucky's Avatar
I don't know where you are, but I've got a complete "parts" 5-speed in my garage that's going on the next scrap load.
I'm in Central Ohio...
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
Replaceing PT cruiser Trans- Prepping trans questions Wiredright Tech & Performance Forum 6 13 Feb 2013 10:59 am
trans pryand62 Tech & Performance Forum 4 08 Feb 2013 11:49 am
help with man trans harrie12348 Tech & Performance Forum 15 27 Apr 2012 10:36 am
5 Spd trans nevinsrt General Turbo Discussions 3 23 Jul 2010 05:01 pm
trans ? ptTurbo528 Tech & Performance Forum 5 29 Jun 2006 09:48 pm
