Thoughts on oil drain valve
Like Tree3Likes
  • 3 Post By NitroPT
Old 17 Feb 2018, 12:01 pm
Macgyverman1123's Avatar
Default Thoughts on oil drain valve
Hey everyone!
My '02 Lte had an almost rounded off oil drain plug when I got it, when it needed an oil change, I just took it to a local shop I trust so as not to risk it. They changed the oil and replaced the drain bolt with an OEM one for no charge.
After these woes, plus the occasional way too tight oil drain, what are your thoughts on those "Easy Oil Drain" valves that replace the drain plug? Do they work? Are there any related issues? Can you still drain 100% of the oil from the crankcase and pan? I guess my biggest worry is that it could somehow come open while I'm driving, but I don't know how rational this is.
Does anyone use on? I'd love to hear from you!
Old 17 Feb 2018, 12:30 pm
rob302's Avatar
Default Re: Thoughts on oil drain valve
personally i would rather get that last 1/8" of oil out the pan and know it's drained completely, since that usually seems to be where all the funky stuff settles. i'm a bit nutty about it though, i usually dump 1/3 or so of a quart of clean oil through just to flush more of the 'old nasty' out.
Old 17 Feb 2018, 12:38 pm
This has always been a common worry/thought about some drain plug additions to various fluid pans not just oil but transmission as well.
The drain plug repair kits and any other drain plug that has the bung inside and raised from the pans floor will not get all the oil drained in the pan. HOWEVER....that oil and any sediments or lost fasteners like that washer while working on the top end on the engine that gets dropped seldom recirculates back into the engine unless you have a circle track car or an engine with a HIGH VOLUME OIL PUMP and spinning the engine at very high RPMs. What I routinely do about every other or so oil change is spray carb or brake clean up into the oil pan drain plug area and stick a pre shape cork in the drain plug hole. Let it set for a few minutes and then drain. Then spray a good dose moving the little red tube all over they place. You will get the settled remainder of grime to exit the drain plug area.
Besides really if you do oil/filter changes at at least 5000 miles or sooner there should be NO sediment accumulating at the bottom of oil pans.
Old 17 Feb 2018, 12:53 pm
Great idea!! Is there any risk of the brake cleaner damaging anything?
Old 17 Feb 2018, 04:19 pm
NO, that's why you are draining it out. Any small residue left I have never seen on any of my oil analysis reports.
I do some other crazy "arse" things at times before an oil change but I can't post them for most certain the ridicule I am sure would follow and my need to defend my response.
Your thoughts on this? whiteclaw General PT Cruiser Discussions 5 25 Jun 2012 07:10 pm
Any thoughts on the E3 Plugs ? 1lowufo Tech & Performance Forum 11 27 Aug 2010 05:48 pm
Thoughts: 06 VS 04 PT purple04 General PT Cruiser Discussions 11 11 Feb 2007 10:12 pm
Break in Thoughts Of Others, LAF General Turbo Discussions 3 16 Feb 2004 04:23 am
P1188 thoughts ,etc. flashbk2 Turbo Performance 12 10 Oct 2003 12:24 am
