Shift Control Module Removal
  • 1 Post By Hollywoodsnake
Old 18 Feb 2018, 05:16 pm
Default Shift Control Module Removal
How do I get to the shift control Module so I can replace it. Have air breather box out, battery and base. Battery support bolted to frame with 4, 15 mm bolts. Of course two are in an area I can not figure out how to get to. Any one tackle this one before?
Old 18 Feb 2018, 05:54 pm
rckstein's Avatar
Default Re: Shift Control Module Removal
To remove the Battery Tray Support Bracket (#7 in the pic), follow this from the Service Manual:
Welcome to the forum
When you get a chance, please go to Welcome New PT Cruiser Members - PT Cruiser Forum and create an intro thread
Old 18 Feb 2018, 08:25 pm
Due to the usual dirt in this area, I recommend you boil a few pots of water to dump around the module and scrub to
make sure this area is clean enough to eat off of before you remove the shift solenoids module.
Dirt is last thing you want to try to clean off after removing the module.
Dry the area with compressed air.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 18 Feb 2018, 09:31 pm
Thanks, couldn't figure how to get to those two that I will have to come from bottom.
rckstein likes this.
Trans. Control module Gramps General PT Cruiser Discussions 2 23 Dec 2014 06:40 pm
Transmission Control Module BoneDaddyCruiser0808 Tech & Performance Forum 4 30 Jun 2013 05:22 pm
Where is the ignition (control) module? bjagd02 General PT Cruiser Discussions 5 26 Feb 2011 05:21 pm
Front Control Module? rose Tech & Performance Forum 10 24 Jan 2011 07:08 pm
