2004 non turbo wiring question
Old 21 Feb 2018, 04:12 pm
Default 2004 non turbo wiring question
If coolant is spilled all over the engine compartment can it cause any wiring to short out? And is there to isolate a short going to a component using OBD 2 tool?
Old 21 Feb 2018, 04:42 pm
Handy_Cruiser's Avatar
Default Re: 2004 non turbo wiring question
A 50/50 mix of water and ethylene glycol (antifreeze base) is not very conductive. With only a 12 volt potential, you are usually not going to see any shorting. And no, there's no real way to assure anything is de-energized based on an OBDII command on a PT Cruiser using just a handheld code reader.
Exactly what are you trying to do? There may be a better way.
Old 21 Feb 2018, 04:55 pm
If I knew what I was doing I wouldn't be sitting here trying to troubleshoot potential issues by looking at a tiny little screen. 😊
I am planning on replacing the radiator fan and was remembering when the timing belt was changed the tech said he spilled coolant all over and it took many days and miles to burn off.
Wondered if he shorted out the fan wiring. Then I watched a YouTube showing how to change the fan and I will likely spill some too... So just trying to make sure I don't get bit twice by the same snake. But if wiring was so dangerous when wet we would all fry alive first time we drove through a bit of precipitation.
OMG maybe that is what's wrong with me! First time I ever drove it was raining and my brain hasn't been the same ever since. 😉
ignition switch wiring question rob342 Tech & Performance Forum 4 22 Feb 2013 04:34 pm
2004 PDC Wiring Diagram? nickcruiser Tech & Performance Forum 4 26 Jan 2013 11:08 am
Wiring question Ttomes Exterior Accessories Forum 2 06 Aug 2012 03:53 pm
Speaker wiring question ? Pa2001 Sound and Security Forum 2 08 Sep 2009 05:54 pm
WTB: 2004 wiring harness, SELL: Wheels 340x Classifieds: For Sale/Trade 1 19 Feb 2009 01:02 pm
