$2800: fair price for a factory reman 2.4l longblock?
Like Tree5Likes
  • 1 Post By FeelthySanchez
  • 1 Post By VsandFords
  • 2 Post By NitroPT
Old 21 Feb 2018, 06:00 pm
FeelthySanchez's Avatar
Default $2800: fair price for a factory reman 2.4l longblock?
Incl 3yr/100K Chrysler nationwide warranty.
The story is our mechanic got it via a clerical goof: the damm thing was drop-shipped from Detroit (arrived Tues Feb 20) after he left a message requesting only a price quote on Fri Feb 16. I was there, live (guess he's got some good credit). He's already offered to install it for $1280, which is a semi-pricey rate for So. Kalif.
Anyway, whatta ya'll think of the price?
I'm pondering grabbing it just for the heckuvit: Mamma's 2001 Limited now sports 264K on the odometer & she wants to keep it, so it's only a matter of time anyway.
Orig owner 100% stock Patriot Blue 2001 LE 5-spd: 283,760 miles & rolling well on it's 3rd ECM, 2nd engine, 3rd gearbox, 2nd rack & pinon.
"The idiot's guide to passing yourself off as leadership" - Ed Hipalito. Author, mgmt failure, narcissistic buffoon.
Old 22 Feb 2018, 01:02 am
_PTGT03's Avatar
Default Re: $2800: fair price for a factory reman 2.4l longblock?
why dont you just buy it since its already delivered and a minute from being installed for you
Old 22 Feb 2018, 06:57 am
That's a whole lot cheaper than a new car. But are you saying it's a complete engine? Does that include the intake and exhaust manifolds and throttle body or would you have to use these parts off your old engine?
Old 22 Feb 2018, 08:02 am
Handy_Cruiser's Avatar
A 2001 Limited with 264,000 miles is worth about $1,000. If you put a $2800 engine in it, it will still be worth about $1,000. There's absolutely no reason to wast this money. And remember, an old worn out car with a new motor will break down just as about as much as one with the original engine due to all the other worn out parts. You will likely get no increase in reliability from the new engine at all. Even with a new engine under warranty, you can still look forward other eventual expensive repairs such as the transmission, starter, alternator, power steering pump, wheel bearings, bell crank, control arms, tie-rod ends, struts, PCM/electrical and the radiator cooling fan which will fail, overheat the new engine and void the warranty. See what I mean?
My choice would be to take the money for the engine and put that in a newer car. For around $3,500, you should be able to purchase a much newer PT Cruiser with lower mileage.
Old 22 Feb 2018, 08:36 am
No, the items below are parts of a complete engine.
A longblock is normally oil pan to valve cover.
chuzz likes this.
Old 22 Feb 2018, 08:47 am
I'd suggest staying on-topic: wasn't looking for a BBV dissertation.
Originally Posted by Handy_Cruiser View Post
A 2001 Limited with 264,000 miles is worth about $1,000. If you put a $2800 engine in it, it will still be worth about $1,000. There's absolutely no reason to wast this money. My choice would be to take the money for the engine and put that in a newer car. For around $3,500, you should be able to purchase a much newer PT Cruiser with lower mileage.
Old 22 Feb 2018, 09:23 am
VsandFords's Avatar
From what I've seen on pricing for Motorcraft/Ford, ACDelco/GM and ATK reman engines, this is not a bad price. The one thing to think about is the warranty starts from your purchase date. To get the full benefit of the warranty, you would want to install it sooner than later. Also, with a reman engine, they usually require the old engine be returned for the core or they will charge a $200-$300 deposit/core charge. Just saying.
NitroPT likes this.
Old 22 Feb 2018, 10:23 am
Yep, good points.
In my case, warranty would commence from date of installation/buyoff (not purchase), & I'm prepared to eat the core chg.
ATK's warranty has my attention, whereas Chrysler's is worth about 2 sheets of Charmin. Ask me how I know
VsandFords likes this.
Old 22 Feb 2018, 10:46 am
Chrysler supplied rebuilt engines use a complete "master engine kit" with the warranty I would say YES to the threads question.
We installed a 2.4 (not a Chrysler supplied engine) at the shop (not a PT) about 3 years ago for close to the same price (1800) but only a standard 12 mos complete labor and 48 engine plus mileage(? I dont remember the mi.)
VsandFords and chuzz like this.
Fair price??? Teo Welcome New PT Cruiser Members 8 05 Jan 2014 08:26 pm
Charlotte Auto Fair SCBluePT Southeast PT Forum 7 06 Aug 2011 10:00 pm
Am I getting a fair deal???? AmandaK General PT Cruiser Discussions 17 10 Dec 2010 05:20 pm
What's best hood bra and a fair price? cemile Exterior Accessories Forum 6 22 Apr 2002 03:28 pm
