Bleeding the coolant system
Old 01 Mar 2018, 07:35 pm
Question Bleeding the coolant system
Hi Everyone,
I bought a no spill funnel mentioned in the overheating threads. After a few cycles most of the air bubbles are out.
1. Do I leave the funnel with 50/50 in the radiator until it cools or remove while hot?
2. When its cold should the filler cap and elbow be full of coolant?
3. Is coolant ever taken from the reservoir tank?
I'm using the Mopar HOAT from the dealer.
Thank you in advance!
2006 PT touring edition, 5 spd manual, 140K, MSD 8.5 mm wires, Champion plugs
Old 02 Mar 2018, 07:03 am
Default Re: Bleeding the coolant system
Originally Posted by discovering06 View Post
Hi Everyone,
If you have time, leave it it installed if hot removal will cause a coolant spill.
Yes, this is a closed system where the cooling system has all air removed. As coolant expands, it is pushed into the overflow bottle. As it cools, it is pulled back into the cooling system.
Yep,see above. After a few hot / cold cycles, the level may drop a bit as the final air is removed from the cooling system.
As a side note, thermostats with a " jiggle pin " are much better in allowing air to escape than regular ones. Also, while filling I elevate the RF of car so cap is high and air escapes.
Old 02 Mar 2018, 02:55 pm
Thank you for the informative reply!
Bleeding air from cooling system bogaz Tech & Performance Forum 16 13 Apr 2016 06:44 pm
Bleeding AIR from cooling system ? rustytoolss General PT Cruiser Discussions 11 22 Sep 2014 10:08 pm
How I bled my coolant system alteet Tech & Performance Forum 4 13 May 2014 11:07 pm
02 BLEEDING COOLANT 02crzr Tech & Performance Forum 7 07 Apr 2012 02:22 pm
Coolant sensor/fan system help please? swordfish Tech & Performance Forum 9 03 May 2010 09:30 pm
