Turbo fuel pump question?
Like Tree2Likes
  • 1 Post By JDK52
  • 1 Post By myckee
Old 10 Mar 2018, 08:55 pm
Default Turbo fuel pump question?
my fuel pump wen tout this week and I need to replace it on my 04 turbo PT.
I see several on Ebay that say there for ones made at different dates? but cant fine one for my PT build date 8/03..most say there for 10/03 on?
I can get one at the local NAPA but there friggin hight $160.
anyone know the diference inthe pumps? there several on ebay for $60..but not for my build date?
Old 11 Mar 2018, 06:08 am
Default Re: Turbo fuel pump question?
If you don't mind a used one, you might contact this member. 2003 GT - "PT Salvage"
Old 11 Mar 2018, 06:54 am
JDK52's Avatar
Have you considered looking into a fuel pump listed for the 2003 Turbo PT?
Rock Auto has a listing with comparable part #s.
Here are those numbers for the Spectra pump for 2003:
Alternate/OEM Part Number(s): 5086650AA, 5086650AB, 5086650AC, RL086650AC
https://www.rockauto.com/en/catalog/...assembly,10147
For the 2004 year Rock offers the pump alone, but for 2003 the pump assembly is the only choice.
That suggests there is a difference between the build date you have and the later date.
Good luck.
myckee likes this.
Old 11 Mar 2018, 08:46 am
As JDK52 mentioned, your early build date indicates at that time they still were using up the leftover 03 parts before switching to the new design. So if you bought the cheap 04 replacement pump with the included filter sock (strainer) from rockauto for about $28, you may have to modify your original 03 style housing to fit it. Even if you had the newer style pump already, there may be some work still required to install the replacement pump, as Chrysler had never intended it to be replaced.
I have seen threads here where people have taken apart the housing and replaced the stock pump with aftermarket pumps. It requires a little bit of modification, but its not too bad I think. I am not sure as I have never done it, so I defer to those who have and who may reply.
If you have little desire, or aptitude for modifying the original housing to accept the new pump, then your only option is to buy the entire housing. At that point, you could probably install the new design instead or continue with the older design. Unless you go for the super cheap new design for ~$81 at rock auto, the new and old designs are similarly priced at $108 at rock auto...plus shipping of course.
If you were going to modify the housing at a later date to accept an aftermarket fuel pump to go racing or whatever, the 03 design looks like it will have a lot more space to fit it in.
JDK52 likes this.
Old 12 Mar 2018, 08:16 pm
does anyone know the actual difference in the early pump vs the later?
2006 (2.4 non turbo) Fuel Pump Resistance betterred Tech & Performance Forum 13 18 Jan 2018 08:11 pm
Fuel pump question oem or ebay ? partyd General PT Cruiser Discussions 22 29 Aug 2015 11:01 am
Replace Fuel Pump 06 Turbo StillCrusin Tech & Performance Forum 5 21 Aug 2012 01:47 pm
Fuel Economy Question - '06 2.4 w/turbo EddieV General PT Cruiser Discussions 15 18 Feb 2011 05:43 pm
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
