PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Tech & Performance Forum (http://www.ptcruiserlinks.com/forum/tech-performance-forum/)
-   -   2004 non turbo cooling fan now runs on high speed all the time (http://www.ptcruiserlinks.com/forum/tech-performance-forum/65715-2004-non-turbo-cooling-fan-now-runs-high-speed-all-time.html)
OldMiner 15 Mar 2018 10:12 am
Not sure which I prefer, a fan that runs intermittently or one that only runs at high speed. I replaced the low speed RELAY and it didn't change anything it still blows only on high speed. I went through a drive through eatery and the window host said he could barely hear me from the order pole because of the fan noise. Anybody know an easy fix?
rsrocket1 15 Mar 2018 05:52 pm
Re: 2004 non turbo cooling fan now runs on high speed all the time
http://www.ptcruiserlinks.com/forum/...icture6261.jpg
If you really want to know. This will turn the fan on from wherever you place the switch and run it with only 100 mA going through the switch and wires and it will stay on as long as the switch is in the on position and never turn off on less you turn it off.
ptcruisersteve 15 Mar 2018 06:35 pm
So the replacement of the radiator fan did not fix the low speed on the radiator fan? Did you test the new radiator fan on both low and high speeds before putting in the Pt Cruiser?
Does the low speed come on when you start the engine cold, turn on the A/C, and start the engine? The low speed on the radiator fan should come on almost immediately.
If the new radiator fan works good on both speeds manually I would suggest first put the original low speed relay back in the Pt Cruiser. Start checking the wiring on the low fan speed side and especially check the radiator fan plug. On one of my new radiator fans I bought I found the radiator fan plug to be defective and I had to replace it with the original radiator fan plug that came out of the Pt Cruiser.
http://www.ptcruiserlinks.com/forum/...tallation.html
OldMiner 15 Mar 2018 07:18 pm
At first, the low speed fan came on instantly with the ac cranked at startup after installing the new fan. And I was relatively certain the low speed relay was working after leaving the dealership after the diagnostic (which was useless because they did not check the wiring yet that's why I took it there) so I assumed it was a bad fan and a new one would solve the issue.
The fan arrived about four days after the promise date. In that short interval while waiting for the part we went from cold weather to smoking hot. I was glad to have ac without risking overheating because also during the wait time for the fan, the old one went back to only operating intermittently. All was well initially after installing it. Low speed came on when it should, and I've never heard the high speed fan due to the wheel noise etc. But I assumed the high speed was always OK because it never overheated (and it has been in some extremely high temps). When we recently went from hot to cold again, when I ran the defrost it sounded like a Sherman tank. And it has never stopped running the high speed fan until today, I let it idle almost 20 minutes before it simmered down. I thought of the plug right away when it started getting wonky but I am not an electrician, in fact wiring confounds me. So I COULD take it to the dealer but if all they're going to do is spin the fan and tell me it works it's of no value.
What diagnostic equipment SHOULD they be using besides eyeballs?
Now it's raining every day since this started and I'm looking for mods like water wings instead of wheels. Might install some oarlocks and try paddling instead. In any case I can't get into it right now without drowning and could ask the dealer to use their equipment but what equipment should they use? YouTube shows a tech using an electronic device to test the relays and all the connections. Shouldn't any dealer worth their salt have similar diagnostic tools?
I guess the big question for now is, will it harm the engine to run the high speed instead of alternating between high and low?
OldMiner 15 Mar 2018 07:38 pm
I really want to know how to dial it back to low and high speed but admittedly confused by wiring. But thank you for mentioning it, will no doubt help someone out there.
OldMiner 15 Mar 2018 07:43 pm
[QUOTE=ptcruisersteve;684146] On one of my new radiator fans I bought I found the radiator fan plug to be defective and I had to replace it with the original radiator fan plug that came out of the Pt Cruiser./QUOTE]
So sure it was a done deal I threw the old fan away in the box from the new. I realized yesterday I might need the old one but waste management already picked up.
ptcruisersteve 15 Mar 2018 08:01 pm
Lets go back to the beginning.
Does the radiator fan come on with the engine cold, turning on the A/C, and starting the engine?
Does the radiator fan come on with the engine cold and first starting the engine without the A/C?
OldMiner 15 Mar 2018 08:05 pm
Affirmative, captain!
OldMiner 15 Mar 2018 08:19 pm
Sorry you edited after I looked at the first q. #1 is yes, #2 is yes also.
I'm meeting a friend in about 10 minutes, will catch up later on "as the radiator fan turns"
ptcruisersteve 15 Mar 2018 08:25 pm
This indicates that the PCM is possibly looking at the low speed relay circuit being open and automatically turns on the high speed on the radiator fan.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
