Air filter hose
Like Tree3Likes
  • 1 Post By rckstein
  • 1 Post By pt06
Old 22 Mar 2018, 11:09 pm
Default Air filter hose
Hello I was changing the battery in my cruiser and in order to do so I have to take the air box out while I was going to put the air box back in the little hose on the side snapped I donít know what itís for or how important it is anything can help thank you
Old 23 Mar 2018, 04:19 am
rckstein's Avatar
Default Re: Air filter hose
That would be the Make Up Air Hose (near the yellow arrow):
Inside the air box will be a small foam Make Up Air Filter:
rsrocket1 likes this.
Old 23 Mar 2018, 08:20 am
But it’s that hose that I’m talking about it broke is it important to replace
Old 23 Mar 2018, 06:56 pm
rckstein's Avatar
When you say "snapped" do you mean that the rubber hose tore and is broken? Or that the nipple connection point on the side of the airbox broke off?
It does serve a purpose, so either way, you should fix it.
If the hose tore, you should replace it.
If the nipple broke off the box, there are some very good plastic adhesives and epoxies that you may be able to glue it back into place. Or you may have to go to a salvage yard and get a replacement airbox.
Old 25 Mar 2018, 03:27 am
The hose and foam filter is important. It keeps grit and sand out of the inside of the engine.
Turbo Coolant hose? Replacement/Hose Size PTTuber Tech & Performance Forum 9 07 Aug 2015 05:27 pm
Rubber Hose on side of air filter box CherylK Tech & Performance Forum 22 22 Nov 2013 06:59 pm
AIr filter box to throttle body coupling hose sscanlan Classifieds: Want To Buy 7 03 Dec 2011 03:40 pm
Issue With my 2001 PT Air Filter/Fuel Filter/Tranny Rekoj Tech & Performance Forum 7 10 Jul 2009 12:27 am
Airraid Intake box + filter + one hose clamp DJmart Classifieds: For Sale/Trade 1 01 Dec 2008 08:14 pm
