Brand new head is timing belt to tight?
Like Tree4Likes
Old 01 Apr 2018, 08:02 pm
Default Brand new head is timing belt to tight?
09 pt cruiser 2.4 non turbo it had burnt exhaust valves so I had the head rebuilt and reinstalled it. It sounds louder now and was wondering if the noise is the timing belt. I think I may have gotten it to tight. Any thiidea guys?.https://youtu.be/8-eo3VguB5A
Old 01 Apr 2018, 10:18 pm
Default Re: Brand new head is timing belt to tight?
What brand timing belt did you install?
Old 01 Apr 2018, 10:19 pm
https://youtu.be/rc7rU9hGCHY
This probably captures the sound better
Old 01 Apr 2018, 10:20 pm
Idk what brand itís was a newer one that was already on it. This is an auction car trying to keep costs down already have over $800 in it lol
Old 01 Apr 2018, 10:50 pm
Handy_Cruiser's Avatar
An over-tight timing belt is going to make a whining sound on the passenger side of the engine. It's pretty obvious if you listen under the hood. It's very similar to the sound that the alternator front bearing makes when the alternator belt is over-tightened or when the bearing in the serpentine belt tensioner is failing.
My advice would be to take the car back to the shop that installed the head. If they are honest, they will check it out and fix any problems they caused. If they give you a reason that's not their fault and it doesn't sound right to you, ask lots of questions and then come back here and post about it. We may be able to let you know if their reason sounds legit or not.
Old 01 Apr 2018, 11:06 pm
I installed it... lol so do I have to tear this all the way back down lol or is there a way to loosen it easier haha
And if I do canít u show me how tight it needs to be
Old 01 Apr 2018, 11:23 pm
And if I do can’t u show me how tight it needs to be
Yes. Here's a photo from my 2005 GT. The spring will need to be centered between the metal tines as shown AFTER the belt has been installed and the engine rotated a few times to let everything setting in.
This is sort of explained in the service manual. If you need a copy, you can download it from my Google Drive here:
https://drive.google.com/file/d/0B9C...ew?usp=sharing
And here's my normal disclaimer:
It should be noted that while I am an ASE Certified Master Automotive Tech and an excellent lover, I primarily work as a Safety Engineer among other things and I haven't worked as a professional mechanic since I was young strapping lad with long sexy flowing hair before college. And even then, I mainly worked on big trucks and heavy equipment. Nowadays, I enjoy working on these funny looking little cars for fun and relaxation. And I help others when I can.
Old 02 Apr 2018, 12:28 am
Crap I donít have that pin can u just by the pin?
Old 02 Apr 2018, 01:00 am
The pin is part of the tension-er and moves as you adjust the tension-er.
Handy_Cruiser likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
2006 Timing Belt, Belt to tight, Won't fit over engine ajhockey3 General PT Cruiser Discussions 34 17 Nov 2017 11:17 am
Original timing belt brand/markings Jfirey General PT Cruiser Discussions 5 20 Aug 2015 08:14 pm
Timing Belt...too tight??? 71cuda2 General PT Cruiser Discussions 7 16 Feb 2015 01:11 pm
Timing Belt Replace- What parts, brand/ johnjsa Tech & Performance Forum 9 23 Jan 2012 11:52 am
timing belt BRAND??? mtnbktrek General Turbo Discussions 3 08 Mar 2009 09:45 pm
