09 pt cruiser serpentine belt slips off ps pully very time I put it on
Like Tree4Likes
  • 1 Post By JoeX
  • 1 Post By rsrocket1
  • 2 Post By _PTGT03
Old 02 Apr 2018, 06:35 pm
Default 09 pt cruiser serpentine belt slips off ps pully very time I put it on
Idk what to do
Old 02 Apr 2018, 06:43 pm
Default Re: 09 pt cruiser serpentine belt slips off ps pully very time I put it on
Are you following the correct belt routing? You should have to release the tension-eer to to get the correct tension on the belt.
rsrocket1 likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 02 Apr 2018, 06:54 pm
rsrocket1's Avatar
Take a look at the alignment of the belt with respect to the pulley and the harmonic balancer (crankshaft pulley) and the p/s pump pulley. The belt should be captured between the walls of the crankshaft pulley and the p/s pump pulley (and A/C pump pulley if you have A/C) and is only riding along on the idler pulley which should be self-centering.
JoeX is correct, you use a wrench on the pulley center bolt to pull the idler pulley up, slide the belt under it, then release the pulley so that it puts tension on the belt.
This isn't a great shot, but look between 0:12 and 0:20 to see it running
Handy_Cruiser likes this.
Old 02 Apr 2018, 08:02 pm
_PTGT03's Avatar
one time i didn't observe the correct belt routing, the belt was too tight and it self-destructed
double check pulley alignment and belt installation
Old 03 Apr 2018, 01:19 pm
I figured it out thanks guys. The harmonic balancer was seared all the way against the crank. Now it runs great
TIME SLIPS??? WPTF General Turbo Discussions 10 01 Mar 2014 06:40 pm
2001 PT Cruiser, screetching serpentine belt? dmorgan924 Tech & Performance Forum 5 30 Jul 2012 01:20 am
PT Cruiser 2.2CRD 2003 (european Model) serpentine Belt Tensioner dustcloud Tech & Performance Forum 2 04 Mar 2011 06:16 am
Changing a 2007 Cruiser Serpentine Belt falconut Tech & Performance Forum 6 20 Mar 2009 08:43 pm
1/8 Mile Time Slips / Wed.12-03 RODRUN Turbo Performance 12 29 Nov 2003 03:32 pm
