Possible Clogged Catalytic Converter
Like Tree17Likes
  #21 (permalink)
Old 16 Apr 2018, 04:33 pm
Default Re: Possible Clogged Catalytic Converter
Originally Posted by Herr_Nomer View Post
I've got my car in the shop now and the mechanic is 50/50 between a clogged catalytic converter or the timing belt having jumped a tooth.
As far as the radiator fan is concerned, low speed doesn't work, but high speed initiates fine.
If you take the Catalytic Converter off the Pt Cruiser you have a pretty good idea if it is clogged up. I used a strong light on one end of the CAT on my Pt Cruiser and with the 02 sensor removed it was obvious on my CAT it was clogged up.
Herr_Nomer likes this.
  #22 (permalink)
Old 17 Apr 2018, 02:18 pm
Originally Posted by rambojoe View Post
a ase certified (or any) mechanic with a vacuum gauge and one good eye wouldn't be 50/50 on anything for more than 5minutes.... just saying.
I was concerned about that, myself. He said he'd have to remove the exhaust manifold to determine a clog, as his removal of the downstream O2 sensor to allow for more airflow didn't steer him toward or away from the possibility of a clog.
Unfortunately, my CAT is welded in or I would've attempted this, myself. I was so disappointed when I crawled under to discover that.
I called back for another update today, and now he thinks there may be another issue, altogether. He says they're getting deeper into the engine and checking the timing and suspects that there may be something else wrong, but didn't elaborate.
  #23 (permalink)
Old 17 Apr 2018, 02:44 pm
How many quarts of engine did it take to bring it to the full line when you found the oil dip stick had no oil on it?
  #24 (permalink)
Old 17 Apr 2018, 04:06 pm
again, all a mechanic needs is a vacuum gauge to see if the cat is clogged- and if cam timing is off.... but I'm stupid, I cant figure out how to quote one line from a post... :/
  #25 (permalink)
Old 17 Apr 2018, 04:29 pm
About 2
  #26 (permalink)
Old 17 Apr 2018, 06:33 pm
rckstein's Avatar
When you click on the Quote button, you can then change, or edit, anything between the 2 Quotes.
For instance in your original post from above, when I clicked Quote, I then removed part of your post.
  #27 (permalink)
Old 18 Apr 2018, 09:27 am
Ok, looks like it's the CAT. Compression test reads 5, apparently
  #28 (permalink)
Old 18 Apr 2018, 10:09 am
When you replaced the timing belt two years ago was the engine head removed and valve guides and seals replaced?
  #29 (permalink)
Old 18 Apr 2018, 10:42 am
Looking at the repair order, now:
Timing belt complete kit -- $302.94
Engine mount - front right upper -- $75.29
Engine mount - front lower -- $84.14
Serpentine belt -- $22.68
Serpentine belt -- $27.03
Labor -- $662.20
  #30 (permalink)
Old 18 Apr 2018, 12:48 pm
Labor -- $662.20
Does it say what brand the timing belt complete kit is? Just wondering if the head gasket kit is included with the timing belt complete kit.
Catalytic Converter - can I do myself? ceil99 Tech & Performance Forum 9 31 Jul 2015 04:51 pm
catalytic converter TheAstronomer Tech & Performance Forum 14 29 Jul 2013 08:10 pm
Catalytic converter & turbo scotchwriter General Turbo Discussions 6 27 Nov 2010 04:35 pm
clogged catalytic coverter what do i do? anthony_plumlee Tech & Performance Forum 8 24 Feb 2009 04:23 pm
Catalytic Converter CHROMEDCRUISER Tech & Performance Forum 2 13 Feb 2005 08:00 am
