Rear sway bar install where none exists now
Old 14 Jul 2004, 11:34 am
Default Rear sway bar install where none exists now
I have a 2003 touring edition with no rear sway bar. Has any one installed a rear bar where no bar originally existed? Was it a benificial change? How difficult was it to install?
Old 14 Jul 2004, 12:24 pm
Your best bet is to do a search within this forum using "sway bars", "anti-sway bars", "Eibach sway bars", etc. However, since we're a friendly bunch, here is my 2 cents.
My PT also didn't come with a rear anti-sway bar. The addition of the rear anti-sway bar dramatically improves handling performance. The car is much flatter in corners and is easier to control. It feels more solid and takes less effort to drive briskly on a curvey road.
There are several brands to choose from including Mopar. You'll need to purchase a hardward installation kit either from your Mopar parts department (lots if individual parts already posted on this forum) or from Eibach (kit #2860.320HKR) in addition to the anti-sway bar. I strongly recommend that you use the same brand for the front and rear bars. Handling is better matched front to rear for a balanced ride. FYI, Mopar is supposed to be releasing a Stage 1 suspension upgrade kit which includes anti-sway bars. You might check into that also.
[IMG]|2003 PT GT 5-Speed | Mopar Stage 1 | Mopar 2.5\" Dual Exhaust | Mopar Short-Throw Shifter | Mopar HO Plastic Intake | Mopar Boost Gauge | AGP WGA/BOP | APC Carbon Fiber Taillights | Axis 19x8 Wheels/Yokohama 225/35ZR19 Parada Spec2 Tires | BTG Strut Tower Brace | BTG Billet Shorty Antenna | Eibach Anti-Sway Bars | HKS SSQV BOV | JLM Motor/Tranny Mounts | KW Variant 1 Coilovers | Maxxfab 3\" Downpipe | NGK Iridiums | Prototypepower UCP/CAI v5 | PTeazer Smoothie Roll Pan | Screamin\' Demon Coil/Livewires | StopTech Slotted Rotors/Hawk HPS Pads/Stainless Steel Lines | Unorthodox Racing Underdrive Pulley|
Old 14 Jul 2004, 12:34 pm
Even though the bar isn't there, the retainer mounts and endlink assembly bolt holes still are. Depending on you r approach, you can do it yourself, all being required is a set of ramps and some tools. If you use the Eibach sways, there is a kit with the endlink assembly. If you use a different bar, then you can get the endlink and retainer clip parts from any dealership. All it is is 2 endlinks, endlink bolts, 2 retainer brackets and their associated bolts.
I did mine, it was fun and saved me 300- in install labor.
Homepage:
Eibach Rear Sway Bar Install Kit SteelBlueGT Turbo Wheels/Suspension/Handling 3 15 Jul 2006 01:54 pm
For Sale - Eibach rear sway install kit PTJim Classifieds: For Sale/Trade 15 12 Aug 2005 01:10 pm
Installed Eibach Anti Roll Kit(Front & Rear Sway) Gear_Head Turbo Wheels/Suspension/Handling 27 28 May 2004 02:05 am
Rear anti-sway bar install on GT JohnM General PT Cruiser Discussions 11 24 Jul 2003 07:38 pm
Rear Sway Install Problem divots Turbo Wheels/Suspension/Handling 6 06 Jul 2003 01:57 pm
  Debt Consolidation | Debt Consolidation | Myspace Layouts | Submit articles | Debt Consolidation
