ONLY COMMUNICATES WITH PCM
NO ABS NO TCM NO SKIM NO INSTRUMENT NO AIRBAG NOTHING ELSE ALL FUSES ARE GOOD.. VIOLET/YELLOW WIRE HAS CONTINUITY EACH MODULE FROM OBD CONNECTOR... PINK GREEN AND PINK/BLUE ALSO HAVE CONTINUITY FROM OBD TO PCM...PCI BUS WIRE IS BETWEEN .5-2VOLTS DISCONNECTED EACH MODULE 1 AT A TIME BUT NOTHING... ALL MODULES HAVE POWER AND GROUND.... PLEASE HELP!!!!!!!!!!!!!!!!!!!! SAMRAAUTOREPAIR@GMAIL.COM |
More information needed.
Any codes? Battery load test done? Can you crank the engine?
If at First You Don't Succeed - Try, Try Again |
Tags |
abs, modules, pci, pcm, tcm |
Thread Tools | |
Display Modes | |
No communication to trans only | Red05PT | Tech & Performance Forum | 2 | 13 Jul 2015 10:54 am |
bought new scan tool, ABS communication trouble | jdlmodelt | Tech & Performance Forum | 6 | 17 Oct 2014 01:37 pm |
no communication from dtc port | goernhrd | General PT Cruiser Discussions | 1 | 09 May 2012 04:05 pm |
Lost Communication With ecm/pcm | oronzo | Tech & Performance Forum | 7 | 20 Aug 2011 07:40 pm |
