How to remove broken off dipstick tube
Like Tree3Likes
Old 18 Apr 2018, 11:29 am
RVC RVC is offline
Default How to remove broken off dipstick tube
It's broken off flush with the top of the engine block with a slight flair on the tube keeping it from going in further. Is there a prescribed method of doing this, or do I just fram around down there until it comes out? Thanks.
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
Old 19 Apr 2018, 09:06 am
rob302's Avatar
Default Re: How to remove broken off dipstick tube
Any luck? I would likely gently screw in a tap and tug on it with one of those vice grip slide hammers
Fk5 and LionPT like this.
Old 19 Apr 2018, 10:11 am
RVC RVC is offline
Great idea! Hadn't thought of that. I'll give it a shot and let you know. Many thanks!!
RVC
Old 19 Apr 2018, 02:27 pm
I drilled a small hole about a half inch in and put a drywall into it and pulled it out. I then found a bolt that fit perfectly in the Dipstick tube and welded it to the top of the dipstick where i removed the rest of the yellow plastic. So I now have a ratrod dipstick. Or you can just buy a new dipstick.
Old 19 Apr 2018, 03:30 pm
rob302's Avatar
i'm under the impression he means the actual tube, not the dipstick itself
Old 19 Apr 2018, 03:36 pm
Azrak's Avatar
Might want to be careful using a thread tap, they can be unpredictably brittle and a real PIA if they snap off. Try your local home hardware/depot to find a Tapcon
screw that would fit, it's worth a try.
2005 Touring Convertible - 2.4L I4 DOHC 16V Turbo Engine - 4-Speed Automatic Transmission.
LT. Almond Pearl Metallic Clear Coat - Black Cloth Top.
Cloth Low-Back Bucket Seats - Dark Slate Gray.
Old 19 Apr 2018, 04:32 pm
RVC RVC is offline
Yes, the tube the dipstick slides down in is what I'm trying to remove. And the Tapcon seems like a good alternate to a tap. Thanks all!
RVC
Old 19 Apr 2018, 05:27 pm
RickinPA's Avatar
Sometimes with tubing it helps to insert a close fitting piece of rod, or the shank of a drill, into the tube to keep it from collapsing. If there is enough tubing sticking out, perhaps reinforcing it by inserting the shank of a drill into the tube stub and grabbing the tubing with a vise grips.
Old 19 Apr 2018, 09:09 pm
Pull the oil pan off?
03 Turbo AutoStick
107K
Cranny
Old 20 Apr 2018, 10:31 am
An easy-out might do the trick. Works for backing out stripped screws.
LionPT likes this.
Dipstick Tube Fk5 Tech & Performance Forum 10 30 Jun 2016 12:47 pm
Air from the Dipstick tube!?!? Tucker05 Tech & Performance Forum 23 14 Mar 2014 09:21 am
Have You Checked You Oil Dipstick Tube Lately? Jetta02awp General PT Cruiser Discussions 15 06 Mar 2011 03:48 am
Engine Oil dipstick handle broke off in tube Samson General PT Cruiser Discussions 8 13 Nov 2010 09:39 pm
Broken dipstick tube white Tech & Performance Forum 2 30 Nov 2008 03:19 pm
