Code P 1684 and P 2074
Old 24 Apr 2018, 10:55 pm
Default Code P 1684 and P 2074
Hello, I have a 2005 Turbo 2.4 Vin E...
Had engine code 0301( misfire Cyl 1). Installed new plugs, wires and coil pack.
On first start engine light on right away, drove for about 20 miles and ran ok but a slight rough.
0301 gone but now P 1684 and 2074 appeared.
Did I forget to plug something back in or???
Thanks,
Paul
Old 25 Apr 2018, 01:29 am
Default Re: Code P 1684 and P 2074
Thanks,
Paul
P0274 = Manifold Pressure / Throttle Position Correlation; High Flow & Vacuum Leak
Possible Causes:
1. Vacuum leak in hoses or component connections
2. High resistance or resistance to ground in MAP 5 volt supply or signal circuit
3. MAP Sensor has failed
4. High resistance in MAP ground circuit
5. Throttle Position Sensor has failed or is improperly adjusted
6. High resistance or resistance to ground in Throttle Position Sensor 5 volt supply or signal circuit
7. High resistance in Throttle Position Sensor ground circuit
8. PCM has failed
Check all the hoses.
1. Inspect the Intake Manifold for leaks and cracks.
2. Inspect the Power Brake Booster for any vacuum leaks.
3. Inspect the PCV system for proper operation or any vacuum leaks.
4. Check all hoses on the turbo.
Old 25 Apr 2018, 01:07 pm
Thank you PT Cruiser Steve !
Old 25 Apr 2018, 05:47 pm
I did this work yesterday (Tues.) 4/24.
So this morning I go out and start the car and....no engine light, so I drove for about 30 miles with a couple of stops...still no engine light.
How does that happen just sitting overnight???
Series of error codes (300, 335, 344, 2074) rotorhead87 Tech & Performance Forum 45 02 Jul 2014 01:04 pm
PT Cruiser Turbo 2074 code won`t go away overhead440 Turbo Performance 2 24 Apr 2013 04:01 pm
1684 code - how long til it clears itself? PTBluiser Tech & Performance Forum 19 20 Jul 2011 07:05 pm
2004 PT with 300/2074 codes WyomingTA Tech & Performance Forum 1 17 Sep 2010 11:49 am
Help needed for P 1684 code JazzeCouture General PT Cruiser Discussions 1 15 Nov 2008 02:07 am
