05 Turbo replaced engine/Trans. mounts, but...
Old 27 Apr 2018, 02:51 pm
Default 05 Turbo replaced engine/Trans. mounts, but...
I still get a clunk noise with slight hesitation upon downshifting -slowing down for stop or off highway offramp... but not everytime...intermittent
(auto Trans) or after initial starting out and hitting higher gear.
Been a long ongoing process starting with motor mount replacement one at a time.
Any suggestion on what I might consider next?
Thank you,
Paul
Old 27 Apr 2018, 04:54 pm
Default Re: 05 Turbo replaced engine/Trans. mounts, but...
I would suggest checking the upper and lower torque struts and if that has been replaced has the 4.720 alignment been done?
Old 27 Apr 2018, 06:34 pm
Ptcruisersteve..
Yes both are new...what is the alignment you're referring to?
Old 27 Apr 2018, 07:49 pm
Originally Posted by paulwells77 View Post
Ptcruisersteve..
There is a step by step procedure to follow to get the 4.720 alignment. It would take too much typing to post it all. You need to have the Factory Shop Manual for your Pt Cruiser so you can make sure you are doing everything correctly. This alignment is important as you can damage your new torque struts if the alignment is off.
Free 01-04 PT cruiser shop manual
Old 28 Apr 2018, 07:39 am
He's talking about the engine alignment. The top mount has to be 4.72" from a hole in the strut tower. If you do a search here, you'll find it. As for the clunking, have you checked your sway bar end links and bushings?
Old 28 Apr 2018, 11:34 am
Passenger side?
Check torque of the bolt at the a-arm ball joint if you disconnected it during your project.
I've had to revisit this bolt on more than one occasion.
Old 29 Apr 2018, 03:55 pm
Thank you all for your replies...
very helpful!
Paul
Replaced ECM, now trans downshifts different Jeffz Tech & Performance Forum 19 02 Dec 2017 08:41 pm
will the turbo engine mounts garyd75 Tech & Performance Forum 12 29 Nov 2016 04:59 pm
Motor Mounts Replaced Now Vibration at Idle falconut Tech & Performance Forum 12 15 Mar 2013 07:48 pm
2004 non-turbo engine mounts replaced cookj Tech & Performance Forum 1 22 Oct 2012 04:31 pm
motor & trans mounts???? tthrift Turbo Performance 13 08 Nov 2003 02:59 am
