Possible ECM Problem?
Like Tree3Likes
Old 29 Apr 2018, 01:18 am
Default Possible ECM Problem?
Tuesday I took the Cruiser out of storage Thursday I'm driving it and the car stalls out.
Called AAA and get it hauled home. Scanned it and it's throwing code P0201 and P0202. So I figure its the injectors as I had to replace #3 injector before (yeah I should have changed them all at the same time)
I replaced all of the injectors Friday night everything's good the car runs great. Tonight I have it idling in the garage and it starts to miss and then shuts down, I start it back up and it idles fine the after a few minutes it misses and shuts down. Scanned it and get P0201. The missing is not consistent as it can idle just fine. for awhile. If it attempts to stall out if I throttle it up and it stays running and will normal out and idles fine for awhile.
Without taking the plenum off the connect for # 1 injector is secure, I can't see any wiring issues
Before I tear it down agaon I had some thoughts and would like you input.
1) the wire to the injector is a problem
2) it's the ECM which I hope it isn't
and 3 although not likely I thought I'd throw it out there. Whats the possibility of bad fuel causing the problem. When I parked it in November it had 3/4 tank. I added stabil Iput a bottle of drygas in it this week. Tonight before the issues started I filled the car up
2002 Limited Edition 2.4 Auto with 177k Miles
Old 29 Apr 2018, 06:16 am
rob302's Avatar
Default Re: Possible ECM Problem?
I'd drive it a while if it is just an annoyance and not a scary problem. Like you said, it's been sitting all winter. You might floor it a bit more than usual, see if that cleans things out
Old 29 Apr 2018, 10:08 am
I just came in from the garage and I don't think I'm going to get off easy. I hit the key and it just cranks no start.
It's a beautiful day today and I was hoping for a drive with the roof open...nope, I'll be in the garage with the hood open instead.
Old 29 Apr 2018, 10:17 am
rob302's Avatar
well after cranking does the exhaust smell like raw gas, or no gas?
Old 29 Apr 2018, 10:54 am
No smell at all
Old 29 Apr 2018, 11:00 am
rob302's Avatar
if it were mine i'd check for fuel pressure(or at least hearing the pump prime) and check the injector pulse with a noid light.
Old 29 Apr 2018, 11:15 am
The fuel pump does run. My first plan of attack was exactly what you suggested with checking the injector pulse.
We'll see how it goes.
rob302 likes this.
Old 29 Apr 2018, 11:16 am
This thread might help you.
2002 PT Cruiser P0201
Old 29 Apr 2018, 11:23 am
try spraying starting fluid in the intake/throttle opening while some one cranks the motor. If it starts you have a fuel delivery problem. Storing vehicles for the winter keeps them clean but algae will grown and clog the in the tank fuel filter/screen causing similar symptoms you describe.
Fuel conditioner does not contain a bio-side to keep the algae from growing. Its a major cause of of small engines failing to start after not using them for months.
Fresh fuel will not wash it out. Just had a friends diesel truck stopped for the same reason.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 29 Apr 2018, 01:58 pm
I went to the parts store and got starting fluid. When I got back I decided to just crank it over. the engine started and ren 10-15 seconds then nothing just cranked.
Cranked it over while hitting it with a little starting fluid. I could keep it running while working the throttle I had to open it pretty far to keep it running. While running it misses and will stall out.
I'm going to test the fuel pressure next.
Just out of curiosity, does "PT" actually mean "part time" Cruiser
Starter problem? Relay problem or others? postbeauty General PT Cruiser Discussions 3 22 Jun 2015 05:52 pm
2001 PT Auto Trans Problem and Engine Rev Problem johnwwjr Tech & Performance Forum 4 18 Apr 2015 10:00 am
AC problem became Overheating problem BilltheBrewer Tech & Performance Forum 1 23 Jul 2014 11:31 pm
Window problem and AC problem kaypriest Tech & Performance Forum 30 04 Jul 2014 07:42 am
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
