0401 code
Old 01 May 2018, 12:31 pm
Default 0401 code
I have an 02 nonturbo that I just put a motor in, it is running fine but I was driving it this morning and it threw a 0401 code, it says itís a egr problem, do I need to replace my egr valve to fix this, thabks
Old 01 May 2018, 02:01 pm
rob302's Avatar
Default Re: 0401 code
you do not need to replace the valve. i fixed mine replacing this.
BUT SINCE YOU JUST DID A MOTOR SWAP..
there are two vacuum lines running from the transducer to the egr valve, and one line running from the transducer to somewhere else. you might investigate those vacuum lines, and make sure the electrical connector is seated properly. the transducer is kinda wedged up under the intake by the firewall.
Old 01 May 2018, 06:34 pm
P0401 - EGR System Fault
Possible Causes:
EGR valve control circuit open, grounded or shorted to power
EGR exhaust transfer tubes blocked in the exhaust manifold
EGR solenoid EGR valve is damaged or has failed
PCM has failed
I would suggest checking to see if the transfer tubes are clogged up.
RockAuto discount code - 5% off code until June 27th,2018 conagan9 PT Pass It On 0 24 Apr 2018 03:25 am
P0401 code keeps coming back but no pending code 96realwe Tech & Performance Forum 8 30 Mar 2017 10:01 pm
P0420 code Converter Code? 2008/110,000 miles Sarasmiles Tech & Performance Forum 8 28 Mar 2014 07:08 pm
Error Code 0401 DeviantPT General PT Cruiser Discussions 13 15 Oct 2012 09:35 am
0401 code erikb41 General PT Cruiser Discussions 5 20 Dec 2007 11:19 pm
