Sudden loss of power, seeming loud intake/exhaust?
Like Tree8Likes
Old 05 May 2018, 01:06 am
Default Sudden loss of power, seeming loud intake/exhaust?
Today I went out to see a movie, about a 20 minute drive from my house. Car felt fine on the way there, no issues. On the way home the car felt like it had lost 20% or so of its power.. Struggled to get up to speed on the free way and then struggled to get up some of the hills near my house.(I live in a particularly hilly area.) I'm pretty mechanically enclined, and have already been inside this engine on more than one occasion. About 10-15k miles ago I did the timing belt, water pump, motor mounts, and a bad head gasket and radiator. I also had the head resurfaced, as it was slightly warped from the overheating caused by a failed radiator. Yesterday I had an issue with the cam position sensor, car seemed to fall flat on it's face under load and threw codes for an intermittent camshaft position sensor. Upon further inspection the connection itself as well as the ground for it appeared to be loose. After cleaning and making sure they were secure, no more issues.
When I got the car home, I noticed a thin white smoke coming out of the tailpipe, and upon popping the hood coming from the header area. I think the smoke from the headers is caused by an oil leak dripping on to the headers, but I can't be sure. I am fairly certain that my PCV is bad, and I noticed today it's line is cracked, which I think is where my oil leak is coming from.
After I saw this, I pulled the car in the garage and did a compression test, fearing another bad head gasket but got ~190 psi on all cylinders, +/- 5 psi. I'm at a total loss as to what could be causing this dip in power. Could my timing have jumped a notch, and that be my issue? I'm not getting a code for a misfire, so I'm doubtful its ignition or fuel. I also thought it could be a clog somewhere in my exhaust, but until tomorrow I can't be sure.
The car runs and drives fine as is, albeit with less power. The idle also doesn't appear to be any different, and it isn't difficult to get started at all. Any ideas?
Old 05 May 2018, 01:22 am
Handy_Cruiser's Avatar
Default Re: Sudden loss of power, seeming loud intake/exhaust?
Fix the PCV valve and hose first. See if that has an effect.
If no joy, check for a clogged catalytic converter. Hook up a vacuum gauge and see if the vacuum drops to near zero with increased RPM.
To check the timing belt, remove #1 spark plug and use a wooden dowel rod or something similar to tell when you get #1 cyl. to the top. Then remove the top of the plastic timing dust cover and see if the timing marks are still aligned on the sprockets.
pt06 and dsab like this.
Old 05 May 2018, 01:30 pm
Checked the timing, everything is still spot on. About to run to an auto parts store to grab the valve and hose. I'll get back here when I put it all back together and test drive it.
Handy_Cruiser likes this.
Old 05 May 2018, 01:53 pm
Check the hose going to the vac buster. Check turbo hoses if yours is. If one goes bad or comes loose. Its loud and no power.
Old 05 May 2018, 04:18 pm
Can you point me to where that is? It's N/A. Replaced the PCV and subsequent hose... no luck. Same symptoms. Took the muffler off just to see if that was clogged, it really didn't get as loud as it was from my muffler delete days. Thinking it might be my cat? Or a stuck exhaust valve? Sounds like exhaust coming from the driver side of the engine bay, almost where the intake is. The power loss is so bad its struggling to get out of first with my foot to the floor.
Old 05 May 2018, 04:26 pm
The brake booster vacuum hose is 3/8 inch rubber and runs from the back of the plastic intake manifold to the brake booster on the drivers side. Here's a photo of where I put a tee in mine for a boost gauge. It's in the same place on the NA PT.
I urge you to try a vacuum gauge. Here's some of the things it can tell you.
Old 05 May 2018, 04:28 pm
This is perfect. I have a gauge, I'll go try it now.
Old 05 May 2018, 04:43 pm
Hooked up a vacuum gauge, looks like the one saying restricted exhaust causing backpressure. Going to try taking off the cat once it cools just as a test.
Old 05 May 2018, 05:29 pm
Yep.
If you've had a blown head gasket in the past which let antifreeze get into the exhaust, your cat may be well coated.
Old 05 May 2018, 06:18 pm
If you live somewhere that you don't have emissions testing, maybe you can punch the crap out of the cat con and stick it back on. Once they're clogged, you'll have a very noticeable decrease in power. Is is glowing red after you drive the car?
sudden very loud turbo whine Kev General Turbo Discussions 24 22 Mar 2015 12:16 pm
Sudden loss of Power Steering after PT being jump started? lanies_ptcruiser02 General PT Cruiser Discussions 16 08 Sep 2010 10:20 am
AirRaid Intake Power Loss Sam2627 Tech & Performance Forum 10 23 Jan 2008 01:30 pm
Sudden drop in power justine311 Tech & Performance Forum 5 21 Feb 2006 11:24 pm
Sudden loss of power(need tune up?) Ctown Tech & Performance Forum 21 16 Jan 2006 08:41 am
