P0700 and P0882
  • 1 Post By moby
Old 16 May 2018, 11:05 am
Default P0700 and P0882
This morning my '06 Touring Edition had the engine light come on and go into limp mode. This was the third time in several months. Each time, it happenned right after beginning to come up to speed after starting out. Also each time, after stopping and restarting the car, the transmission shifts and operates normally again. Same diagnostic codes were present each time, as well.
I have searched the forum and checked my ground wires for corrosion (the cheapest and easiest possible fix found). I wanted to ask for any suggestions before throwing new parts at it. Thanks in advance!
Old 16 May 2018, 11:11 am
LionPT's Avatar
Default Re: P0700 and P0882
Check you battery & connections. P0882 is a Low Voltage code & could cause your other code.
Old 18 May 2018, 07:37 am
Thanks, LionPT, for the response. The battery checked out good per Advance's tester. I also removed, brushed/cleaned the - and + connections and reinstalled. We will see what happens.
Old 18 May 2018, 10:51 am
LionPT's Avatar
I know you said you checked the grounds, but double check the ones behind the air box...remove them to verify that they are ok.
Old 19 May 2018, 03:44 am
There are 2 small ground screws on the left front inner fender on the 2006 PT's.
I'd pull the cover off the TIPM and check for corrosion on the fuses. Seal the cover tightly when done.
Old 29 Sep 2018, 07:36 pm
Best Fix... Remove the T.I.P.M. Go on Ebay. Find one with the exact same code numbers, and replace it!!! After beating this P0882 car runs great, worked for me .
rockandroller likes this.
P0882 Low input signal dhtmldude Tech & Performance Forum 20 02 Aug 2019 10:58 am
2006 PT P0882, P0700 Non Turbo Recommended Trouble Shooting Sequence? pjfent General PT Cruiser Discussions 22 27 Jun 2018 02:03 am
P0882 Power input low - Diag. Procedure Sexygomer General PT Cruiser Discussions 0 14 Apr 2016 07:45 am
Engine Light Code P0882 Flpt2 General PT Cruiser Discussions 7 28 Jul 2015 08:37 am
2006 pt cruiser touring sedan p0882 p0700 theholdenz Tech & Performance Forum 1 01 Jul 2015 08:25 pm
