REVERSED LEADS FROM PORTABLE JUMP STARTER
Old 20 May 2018, 03:00 pm
Default REVERSED LEADS FROM PORTABLE JUMP STARTER
Guys, I'm really embarrassed to admit that I hooked up a portable jump starter backwards. My battery was completely dead at the time. I hooked the negative cable to the built in positive post, and the positive cable directly to the positive post on the battery. Needless to say, there was sparks. It did destroy the portable starter (EverStart 750 amp) I'm getting a new jump starter today and an nervously waiting to hook it up and see if my car will start...Or do you think I ruined any components in the electrical system of the 2004 PT Cruiser. If so, what might I have destroyed beyond fuses?
Thanks Jim
Old 20 May 2018, 03:47 pm
LionPT's Avatar
Default Re: REVERSED LEADS FROM PORTABLE JUMP STARTER
Being it's pre-canbus..2006...your odds are good.
Old 20 May 2018, 03:51 pm
Thanks for the quick response LionPT. I sure hope you are right. Will update results when I try to jump it again.
Old 20 May 2018, 04:52 pm
rob302's Avatar
you might check a few fuses ahead of time to save a trip to the parts store
Originally Posted by CREWZIN View Post
You hooked the battery up backwards!!!! There's particular fuses you probably fried in the PDC (fuse box in the engine compartment?
No#1 30 amp Ignition start.
No#3 40 amp Ignition Run
No#13 20 amp Auto Shut Down
No#17 15 amp IOD
Check them all really well.
Old 20 May 2018, 06:18 pm
VsandFords's Avatar
Thanks Jim
If you hooked both leads from the jump box to the positive side, you did nothing but short out the jump box. It would be like taking a foot long cable and attaching the positive to one end and the negative to the other. None of the vehicle electronics would be affected.
how come I'm blowin' fuses and image is reversed. ptprice Members PT Project 11 23 Jan 2016 06:59 pm
Starter, starter relay or alternator?? mlpluess Tech & Performance Forum 18 30 Nov 2015 07:49 pm
Reversed battery connections- help chuck2112 Tech & Performance Forum 3 12 Jan 2014 08:28 pm
Door lock reversed blitterbit General PT Cruiser Discussions 2 05 Jul 2013 11:29 am
can anyone give me leads :( Johns03PT General PT Cruiser Discussions 10 07 Mar 2012 07:53 pm
