top tranny leak
  • 1 Post By rob302
Old 21 May 2018, 12:21 pm
Default top tranny leak
I found that the trasmission is covered in oil on the top, under the fuse box . but i dont see how it could be leaking from the top part. Powersteering is always full.trasmission gets low on oil about once a month i check it and is a quart low. Any idea where it could be coming from?
Old 21 May 2018, 06:00 pm
rob302's Avatar
Default Re: top tranny leak
Is it covered in oil, or transmission fluid? What color is it? What does it taste like?
chuzz likes this.
Old 22 May 2018, 05:07 am
transmissions don't burn oil, they leak, do you have a oil spot on the ground where you park?
Oil on top of the engine could be coming from seal on cam sensor or valve cover, PVC hose.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 22 May 2018, 09:14 am
might be oil coming from the drain hole in the breather box.
Old 24 May 2018, 04:59 am
If it is trans fluid, i'd check the clamps on the front of the trans. There are 2 rubber hoses coming from the radiator.
Answer to tranny leak krw General PT Cruiser Discussions 1 23 Mar 2016 10:38 am
Tranny leak conleyrb100 Tech & Performance Forum 3 19 Jul 2015 02:20 pm
Tranny Fluid leak :/ need some assistance NicksCruiser Tech & Performance Forum 29 16 Oct 2012 09:23 pm
Oil Leak...replace tranny hose mstyler05 Tech & Performance Forum 2 11 Jan 2011 12:11 am
tranny leak steve smith Tech & Performance Forum 1 17 Jun 2005 05:08 pm
