ongoing problem after head gasket job
Like Tree10Likes
  • 2 Post By ptcruisersteve
  • 2 Post By rcktpwrd
  • 4 Post By 944tim
Old 07 Jun 2018, 05:37 pm
Default ongoing problem after head gasket job
ok 2006 TE non turbo.
had the dreaded PT Gurgle, did combustion gas test , positive. We pulled the head, replaced head gasket, all the upper end gaskets, the belts and alternator were brand new.
No Start.
cranks, has fuel pressure.
DTC codes
PO107 Manifold pressure
PO127 Throttle position sensor
PO335 Crank shaft sensor
PO 340 Cam position sensor
Crank and Cam sensors are new others not
We have not decided whether it is the wiring harness(connections or bad wires)
or is it one or more of the sensors?
BTW we think we figured out why the head gasket leaked, More than one of the head bolts were not torqued correctly due to oil in the holes- hydro locking- thus uneven torque from the PO
So, tomorrow, we are going to inspect and clean/grease all connections and go from there.
Retired after 45 years, worked at various things, ran a business for a while.
Married 3 kids, 2 grandkids
Daily Driver 2006 PTC,
hobby car:87 Porsche 944, currently in restoration mode.
99 F250 for hauling stuff.
Old 07 Jun 2018, 06:24 pm
Default Re: ongoing problem after head gasket job
I would suggest checking to see if your camshaft sensor connector and your coil pack connector got switched.
rcktpwrd and dsab like this.
Old 07 Jun 2018, 06:40 pm
rcktpwrd's Avatar
Cool Re: ongoing problem after head gasket job
I agree with Steve, this has been a documented and somewhat common issue when there has been that kind of work done and so much disassembled.
Why both sensors use the same connector and the harness is that easily mixed up is a bad design!
ptcruisersteve and dsab like this.
Joel
www.rcktpwrd.com
Old 07 Jun 2018, 09:10 pm
DTC codes
Crank and Cam sensors are new.
How new? Were they recently replaced to troubleshoot this problem or recently changed and the car ran fine on the new sensors? If Steve's suggestion on checking for a swapped connection doesn't resolve you problem, and you had swapped these sensors out to resolve your codes, I'd suggest going back with the original sensors. No sense in wondering if the new sensors are good or bad or you have a wiring problem, best to isolate by going back to the last known good configuration and go from there.
Old 08 Jun 2018, 02:33 am
The cam position sensor connector is the one containing the SOLID-orange colored wire.
Old 08 Jun 2018, 08:18 am
[QUOTE=Grasshopper77;689684]How new?
last month did the belts and water pump because it was time, the alternator because we were in there. at that time did the cam sensor at Steves' suggestion.
At this point we are checking the connection ends again as steve suggested.
we will post what happens
Old 08 Jun 2018, 11:19 am
Handy_Cruiser's Avatar
No Start.
DTC codes
First, make sure the plugs on the camshaft sensor and ignition coil have not been reversed. They are the SAME plug.
If no joy, remove the top dust cover from the timing sprockets. Then remove #1 spark plug and get the cylinder all the way up on the compression stroke. Now see of the timing marks on the sprockets align. If the engine was not timed correctly, you would likely get the cam and cranks sensor codes while trying to start it.
Old 08 Jun 2018, 02:17 pm
Good to see other members agree with my post of checking to see if the connectors got switched.
Handy_Cruiser and JoeX like this.
Old 09 Jun 2018, 04:18 pm
I did as ptcruisersteve said and switched the 2 connectors and everything works as it is supposed to. Cleared the codes and now we are going on a test drive.
Thank You Steve, your help is invaluable. !
Tags
4 dtc codes
ongoing Starter problem schism Tech & Performance Forum 12 31 Jan 2016 07:10 pm
Head Gasket Problem? PianoTunerCruiser General PT Cruiser Discussions 20 22 Aug 2012 05:25 pm
Head gasket problem CVS General Turbo Discussions 14 03 Jul 2012 12:36 pm
Whats the Head flat spec. for head gasket. Busted_PT Tech & Performance Forum 7 26 Apr 2012 08:16 am
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
